Bagufr 6 Posted February 1, 2024 Posted February 1, 2024 Hello, I'm having a rather strange problem. I've bought an Emby Premiere licence, and locally everything's fine. On the other hand, using emby on my synology nas, I use a reverse proxy to access it from outside with one of my sub-domains. Everything is fine, except that when I access it via my domain name, the "premiere" version is not detected. Do you have any idea how to solve the problem? Thanks
Luke 42241 Posted February 1, 2024 Posted February 1, 2024 HI there, what makes you think the Premiere version isn't' detected?
Bagufr 6 Posted February 1, 2024 Author Posted February 1, 2024 The big logo "Obtain Emby Premiere" and some options in admin section not available. (Available when access from the same account on local lan) And last, theme options are not kept between LAN and public access.
Bagufr 6 Posted February 2, 2024 Author Posted February 2, 2024 Yes In firefox and chrome, same result
Luke 42241 Posted February 2, 2024 Posted February 2, 2024 What address is in the browser address bar?
Bagufr 6 Posted February 2, 2024 Author Posted February 2, 2024 (edited) When i'm in local lan, i use my synology address (local only) http://172.16.x.y:8096 When i'm outside, i use my domain adress https://myserver.domain.fr Here is my reverse proxy config : <VirtualHost *:443> ServerName myserver.domain.fr SSLEngine on H2Direct On H2Upgrade On DocumentRoot ${APACHE_WORK_DIR}/folder/html/emby/ SSLProxyEngine on SSLProxyVerify none SSLProxyCheckPeerName off SSLProxyCheckPeerCN off SSLProxyCheckPeerExpire off ProxyAddHeaders off ProxyPreserveHost on ProxyReceiveBufferSize 4096 ProxyPass / http://172.16.x.y:8096/ Keepalive=On ProxyPassReverse / http://172.16.x.y:8096/ Keepalive=On setenv proxy-initial-not-pooled 1 SSLCertificateFile ${CERT_DIR}/fullchain.cer SSLCertificateKeyFile ${CERT_DIR}/cert.key SSLCACertificateFile ${CERT_DIR}/cacert.pem SSLUseStapling on <Directory ${APACHE_WORK_DIR}/folder/html/emby/> Options +FollowSymLinks -Indexes +Includes +ExecCGI AllowOverride None <RequireAll> Require all granted Require not env BlockCountry </RequireAll> </Directory> </VirtualHost> Â Edited February 2, 2024 by Bagufr
Luke 42241 Posted February 3, 2024 Posted February 3, 2024 Have you compared your reverse proxy settings to this? I know it's for nginx but most reverse proxies have similar options.
Bagufr 6 Posted February 3, 2024 Author Posted February 3, 2024 (edited) I don't see any real difference. Maybe "ProxyAddHeaders off" wich may be set to "on" I will try and tell you the result : Edit : Same result Edited February 3, 2024 by Bagufr
Luke 42241 Posted February 4, 2024 Posted February 4, 2024 Can you capture the contents of the browser debug console? Are there any browser extensions installed?
Bagufr 6 Posted February 4, 2024 Author Posted February 4, 2024 I don't understand what you need. But... I did a test. I made a reverse proxy directly in the synology NAS. Since I have a DDNS with a valid lets encrypt certificate, all I have to do is add a redirection of port 9443 in my router. -- See attached file -- In this configuration, the emby premiere account is detected. So there is something preventing emby from identifying the subscription when you use a reverse proxy with the above configuration. If I test a little further, if I go through the apache reverse proxy, I get an error message telling me that no stream is available when I try to read content. But if I use the nas reverse proxy, everything works perfectly.
Bagufr 6 Posted February 5, 2024 Author Posted February 5, 2024 I can send you, but in private, embyserver log file and ffmpeg transcode log file i you want.
Luke 42241 Posted February 11, 2024 Posted February 11, 2024 On 2/5/2024 at 8:23 AM, Bagufr said: I can send you, but in private, embyserver log file and ffmpeg transcode log file i you want. I don't think this is going to help us. I think the question is what's different about your configuration between the two reverse proxies?
Bagufr 6 Posted February 11, 2024 Author Posted February 11, 2024 I don't really know In fact, my original reverse proxy runs under apache. The other runs under nginx on my nas server. As the problem is too serious, I'm in the process of moving my emby server directly to the web server.
Luke 42241 Posted February 11, 2024 Posted February 11, 2024 OK please let us know if you find anything. Thanks. 1
Solution DonMacaroni 55 Posted February 13, 2024 Solution Posted February 13, 2024 (edited) Quite interesting, I have pretty similar setup (no DDNS though, but static DNS) and no issues:   @Bagufr I do think, your destination hostname is wrong, though... Under the hood, it looks like this:  server { listen 8888 ssl; listen [::]:8888 ssl; server_name syno.darktech.lan ; if ( $host !~ "(<obfuscated>$)" ) { return 404; } include /usr/syno/etc/www/certificate/ReverseProxy_cd582aff-938a-4512-89f6-ac49ebedfcee/cert.conf*; include /usr/syno/etc/security-profile/tls-profile/config/ReverseProxy_cd582aff-938a-4512-89f6-ac49ebedfcee.conf*; add_header Strict-Transport-Security "max-age=15768000; includeSubdomains; preload" always; proxy_ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; location / { proxy_connect_timeout 60; proxy_read_timeout 60; proxy_send_timeout 60; proxy_intercept_errors off; proxy_http_version 1.1; proxy_set_header Host $http_host; proxy_set_header X-Real-IP $remote_addr; proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for; proxy_set_header X-Forwarded-Proto $scheme; proxy_pass http://localhost:8096; } error_page 403 404 500 502 503 504 /dsm_error_page; location /dsm_error_page { internal; root /usr/syno/share/nginx; rewrite (.*) /error.html break; allow all; } }  Edited February 13, 2024 by DonMacaroni 1
Bagufr 6 Posted February 18, 2024 Author Posted February 18, 2024 Hi, I made a mistake when editing my screenshot. On my nas server, I had localhost as the destination. But as explained earlier, I moved the emby server. Now, the emby server is on the same server as the web server and fetches the media from the nas server. This gives me better performance and makes it easier to manage SSL certificates. I think I had another problem with certificate management on my synology server. I made some changes on my nas server to get a letsencrypt certificate through the back door. If I had to do the same thing again, I think everything would work correctly with the synology reverse proxy. 1 1
Carlo 4561 Posted February 19, 2024 Posted February 19, 2024 @BagufrSo you're all good for now correct? Carlo
