Mahinepua 82 Posted January 30, 2024 Posted January 30, 2024 Is there a setting within Theater so the highest quality language specific audio stream is selected in lieu of the default? Kodi, potplayer and LAV filters for example have such a setting.
Luke 42235 Posted January 30, 2024 Posted January 30, 2024 Hi, have you explored your Emby user audio settings?
Mahinepua 82 Posted January 31, 2024 Author Posted January 31, 2024 Hi Luke, nothings jumping out at me. I've looked through the Emby Theater audio settings and a few other areas and cant find a 'prefer highest quality stream' or similar option. I'm not talking about manual selection at the menu screen before playing a movie but defaulting automatically. Can you or someone point me in the right direction please?
Luke 42235 Posted January 31, 2024 Posted January 31, 2024 There isn't an exact setting for this, but there are other audio settings in the user profile options that might help.
Mahinepua 82 Posted January 31, 2024 Author Posted January 31, 2024 (edited) Cheers Luke, cant see anything. I wonder if there is a MPV.conf setting that can be made to override the default emby audio selection? Example of LAV demux setting below. Edited January 31, 2024 by Mahinepua
Luke 42235 Posted January 31, 2024 Posted January 31, 2024 Quote Cheers Luke, cant see anything. Try clicking your user icon -> playback settings. Again I realize it's not what you need, just making you're aware they are there.
