Dez_Lamar 10 Posted January 29, 2024 Posted January 29, 2024 I've been having an issue with the TV guide refreshing, it gets to 15% and hangs. I was wondering if clearing the server cache would resolve this problem.
Luke 42184 Posted January 29, 2024 Posted January 29, 2024 Hi there, what makes you think it hangs? How to Report a Problem
Dez_Lamar 10 Posted January 29, 2024 Author Posted January 29, 2024 2 minutes ago, Luke said: Hi there, what makes you think it hangs? How to Report a Problem It's been sitting at 15% for a week now and I only have 8 channels. I've tried stopping it but it'll get stuck doing that. I am using the virtual TV plug-in I'm not sure if that has any to do with, but even when I used IPTV channels it did the same thing.
Luke 42184 Posted January 29, 2024 Posted January 29, 2024 Please attach the Emby server log. Thanks.
Dez_Lamar 10 Posted January 31, 2024 Author Posted January 31, 2024 On 1/28/2024 at 8:57 PM, Luke said: Please attach the Emby server log. Thanks. embyserver.txt
Dez_Lamar 10 Posted February 6, 2024 Author Posted February 6, 2024 3 hours ago, Luke said: Hi, has it completed? Yes, but not loading any new channels I make with the virtual TV plug-in
bfir3 117 Posted June 1, 2024 Posted June 1, 2024 I'm having this same issue after adding VirtualTV plug in. Not saying it's related but that's when I noticed it as well. Stuck at 15%.
pünktchen 1410 Posted June 1, 2024 Posted June 1, 2024 6 minutes ago, bfir3 said: I'm having this same issue after adding VirtualTV plug in. Not saying it's related but that's when I noticed it as well. Stuck at 15%. Server and plugin version?
bfir3 117 Posted June 2, 2024 Posted June 2, 2024 3 hours ago, pünktchen said: Server and plugin version? I don't have it on hand but in my case at least, I think it was due to user error. I had a rule setup that wasn't being interpreted properly due to including parenthesis. After fixing that rule, the guide refresh finishes in a very timely manner. Thanks! 1
hadim 4 Posted June 2, 2024 Posted June 2, 2024 Same issue here. It is stuck at 15% using 4.9.0.22 beta.
Happy2Play 9798 Posted June 2, 2024 Posted June 2, 2024 14 minutes ago, hadim said: Same issue here. It is stuck at 15% using 4.9.0.22 beta. same request applies
meep 1 Posted August 26, 2024 Posted August 26, 2024 I'm having the same issue with Live TV. Import gets to 15% in Scheduled Tasks and then appears to stall. Emby server eventually freezes, requiring a restart. Server: 4.8.8.0 embyserver.txt
Luke 42184 Posted August 26, 2024 Posted August 26, 2024 1 minute ago, meep said: I'm having the same issue with Live TV. Import gets to 15% in Scheduled Tasks and then appears to stall. Emby server eventually freezes, requiring a restart. Server: 4.8.8.0 embyserver.txt 735.02 kB · 0 downloads Hi, looks like it is still processing. I would just be patient and allow it to finish. Please let us know if this helps. Thanks.
Happy2Play 9798 Posted August 26, 2024 Posted August 26, 2024 2 hours ago, Luke said: Hi, looks like it is still processing. I would just be patient and allow it to finish. Please let us know if this helps. Thanks. I guess the issue is what has it been doing for 15 minutes then? But need more log to provide more information. 2024-08-26 19:50:25.172 Info SqliteItemRepository: Removing 1 old programs from channel 269045 UK: ESPN PLUS 20 PPV 2024-08-26 20:05:33.716 Info App: Sqlite: 284 - automatic index on LastWatchedEpisodes(SeriesPresentationUniqueKey)
