fretwork 0 Posted January 28, 2024 Posted January 28, 2024 I want to place transcoding temp on a separate disk but cannot get Emby to recognize my "Transcoding temporary path" setting. I run Emby dockerized and I have mounted the disk on /mnt/transcode in docker-compose.yml: volumes: - /mnt/transcode:/mnt/transcode - ./config:/config I have changed the setting in Emby: But Emby still uses the default folder, which is confirmed by the log: Why doesn't Emby respect the setting?
Solution Q-Droid 1011 Posted January 28, 2024 Solution Posted January 28, 2024 It's a logging bug on startup. The defined path is still used and the logged entry is correct when the server log is rotated. Try a manual log rotation from Scheduled Tasks after the server starts and check the value in the new log.
Luke 42244 Posted January 28, 2024 Posted January 28, 2024 This has been resolved in the upcoming 4.8 server release. Thanks.
