fcorona76 3 Posted January 28, 2024 Posted January 28, 2024 I just bought into a new nvidia shield for it's ability to decode high bitrate audio from my local emby server. The problem is that it stutters video horribly when using high band width audio (DTS-MA, TrueHD, and even multi-channel PCM when I disable passthrough) but the audio plays fairly smooth. The stutter is not constant but it is consistent at certain points of a movie. All of my media is self made MKV's, from my own blu rays, using Handbrake with HEVC video (less than 10mbps ususally) and uncompressed pass-through audio tracks (DTS-MA, TrueHD, and AC3 for fall back so Emby wont have to transcode). As soon as I switch back to the AC3 track the stuttering goes away. If I start with Ac3 there is never a stutter. This is not in the source as I can watch it from my phone or PC with no statter at ll, regardless of audio track selection. I do not have problems when playing this exact same media through VLC on the Shield so I don't believe it to be an HDMI or, router of wiring problem. I have already gone through and tried a lot of the other solutions for similar forum posts. I have side loaded the latest Android Emby with no change. Cleared cache and data with no change. Made all of the shield changes to audio processing and all of the emby client changes too with no change to the problem. If I setup the AndroidTV client to use an external player the problem does go away but this is not the solution I want as it breaks the user experience of integration in Emby. I already sent a log so hopefully you can find it. Nvidia Shield Pro (2019) - Brand new and two days out of the box. All up to date and wired gigabit ethernet UnRaid 6.12.6 on an AMD 5900x, 32gb ram, NVME cache drive, etc and little else running on it. No CPU ever when streaming from emby. Emby server running in a docker and always up to date (4.7.14.0 currently) Log sent 01-27-24 around 6:00-6:15CST Watching The Dark Knight.MKV The stutter is consistent around the 00:00:55 to 00:01:15 mark The User name is User in server UnRaid
Luke 42243 Posted January 28, 2024 Posted January 28, 2024 Quote I have side loaded the latest Android Emby with no change. Hi, what version number did you try?
fcorona76 3 Posted January 28, 2024 Author Posted January 28, 2024 8 minutes ago, Luke said: Hi, what version number did you try? There was no improvement with the standard Android package. I tried that this afternoon and downloaded direct from: https://emby.media/emby-for-android.html The package name is below but I don't recall the version number. It's whatever was up there 7 hours ago. emby-android-google-arm64-v8a-release.apk
Luke 42243 Posted January 28, 2024 Posted January 28, 2024 Hi, can you obtain an android app log by following the instructions here: Thanks.
fcorona76 3 Posted January 28, 2024 Author Posted January 28, 2024 (edited) 8 hours ago, Luke said: Hi, can you obtain an android app log by following the instructions here: Thanks. Absolutely! I removed the Emby for Android TV, reinstalled the latest Emby for Android build (from yesterday) and ran the log per your instructions. I stopped the log about 20 seconds after this particular hiccup corrected itself. Again, the stuttering starts around the 55 second mark and runs through to about 1 minute and 10 seconds give, or take, a couple. emby_android_1706452033963.txt Edited January 28, 2024 by fcorona76 added info
fcorona76 3 Posted January 28, 2024 Author Posted January 28, 2024 I watched a few other movies today and found that this stuttering is happening with *all* multi-channel tracks including standard Ac3 in both the Android and AndroidTV versions of Emby. None of the problems exist in VLC or MX player on the Shield. I also found that enabling "Playback correction" in the AndroidTV app did not help at all. I had NONE of these problems using Emby on the Roku 4K stick, on WiFi, just a few days ago though it would automatically downscale the formats down to Dolby Digital or plain DTS. I watched my ethernet port usage on the UnRaid server and, aside from a startup buffering where the shield pulled down about 300-400mbps for a brief moment, the upload speed never exceeds 10-15mbps even during the stutters. I'm going to try a new encode of the exact same source with the TrueHD track converted down to Stereo Audio MP3 320kbps, with no other tracks, and another with no audio track at all to see if the multi channel is a problem or just the video/encode in general.
fcorona76 3 Posted January 29, 2024 Author Posted January 29, 2024 All of this is using Emby Android TV from the play store. After encoding the exact same source, with the exact same profile, I saw zero stuttering when there was no audio track present. Audio Output is set to auto. When there was only a stereo encoded audio track there was also no stuttering. Audio Output is set to auto. When I try to play DTS or TRUEHD that was passed through it stutters. Audio Output is set to auto. When I try to play AC3(Dolby Digital 5.1) that was passed through from the source it stutters. Audio Output is set to auto. When I try to play DTS or TRUEHD that was passed through but set Audio Output to "Convert" it does not noticably stutter.Enabling Stats for Nerds still says it is playing a DIRECT TrueHD stream. My Denon reciever says it's being passed, and playing, a Dolby Digital 5.1 stream. Emby server shows that it is definitely transcoding audio even though the client says it's not.
ebr 16335 Posted January 29, 2024 Posted January 29, 2024 Hi. Have you tried toggling the "Dolby processing" option in the Shield settings?
rbjtech 5341 Posted January 29, 2024 Posted January 29, 2024 (edited) How are the devices physically connected ? -- Emby Server - Unraid NAS > Ethernet > Shield Pro Emby Client - Shield Pro (HDMI Out) > HDMI 2.0 > AVR (HDMI In) AVR (HDMI Out/Monitor) > HDMI 2.0 > TV (HDMI In - Doesn't matter if it's ARC/EARC or not - you are not using ARC - infact you are not using Audio as it terminates on the AVR, you are just passing Video at this point) -- Shield itself should be set to 'Auto' on all the Audio Passthrough options - you can invididually set them if you like but I have mine set to Auto and passthrough all HD Codecs just fine. Untick Dolby processing as @ebrsays above. Edited January 29, 2024 by rbjtech
fcorona76 3 Posted January 30, 2024 Author Posted January 30, 2024 10 hours ago, rbjtech said: How are the devices physically connected ? -- Emby Server - Unraid NAS > Ethernet > Shield Pro Emby Client - Shield Pro (HDMI Out) > HDMI 2.0 > AVR (HDMI In) AVR (HDMI Out/Monitor) > HDMI 2.0 > TV (HDMI In - Doesn't matter if it's ARC/EARC or not - you are not using ARC - infact you are not using Audio as it terminates on the AVR, you are just passing Video at this point) -- Shield itself should be set to 'Auto' on all the Audio Passthrough options - you can invididually set them if you like but I have mine set to Auto and passthrough all HD Codecs just fine. Untick Dolby processing as @ebrsays above. Dolby processing is off in the shield settings. Pretty close on the hardware connection... Emby Server - Unraid NAS > Gigabit Ethernet > Shield Pro Emby Client - Shield Pro (HDMI Out) > HDMI 1.4 > AVR (HDMI In) (Denon AVR-300 that does support all of the audio formats that I am working with) I'm only dealing with 1080p content, for now, so the avr using HDMI 1.4 shouldn't be an issue with my lower but rate video feed paired with the passed through, uncompressed, audio. Also as I stated: if I change nothing on the shield, other than set Emby to use VLC as an external player, all of the audio codecs do what they're supposed to and there is no video stutter. I'm going to try double, and triple, check all of the shield settings to make sure there's nothing weird set by accident. 1
rbjtech 5341 Posted January 30, 2024 Posted January 30, 2024 7 hours ago, fcorona76 said: Dolby processing is off in the shield settings. Pretty close on the hardware connection... Emby Server - Unraid NAS > Gigabit Ethernet > Shield Pro Emby Client - Shield Pro (HDMI Out) > HDMI 1.4 > AVR (HDMI In) (Denon AVR-300 that does support all of the audio formats that I am working with) I'm only dealing with 1080p content, for now, so the avr using HDMI 1.4 shouldn't be an issue with my lower but rate video feed paired with the passed through, uncompressed, audio. Also as I stated: if I change nothing on the shield, other than set Emby to use VLC as an external player, all of the audio codecs do what they're supposed to and there is no video stutter. I'm going to try double, and triple, check all of the shield settings to make sure there's nothing weird set by accident. That's all setup fine. How about an official 'demo' file from the likes of https://www.demolandia.net/cinema/dolby-demo-trailers-hd/page-8.html Do these play ok ?
ebr 16335 Posted January 30, 2024 Posted January 30, 2024 13 hours ago, fcorona76 said: Dolby processing is off in the shield settings. For kicks, try turning it on and see if anything changes.
fcorona76 3 Posted January 30, 2024 Author Posted January 30, 2024 8 hours ago, ebr said: For kicks, try turning it on and see if anything changes. No help. I even went the route of a full factory reset and only installed Emby. It still stutters using the Emby player.
fcorona76 3 Posted January 31, 2024 Author Posted January 31, 2024 15 hours ago, rbjtech said: That's all setup fine. How about an official 'demo' file from the likes of https://www.demolandia.net/cinema/dolby-demo-trailers-hd/page-8.html Do these play ok ? They all work incredibly well in Emby using the stock settings on the shield after a factory reset. My receiver and TV handled all of the audio formats just fine from every one of them. But not all of my media is having a problem either. So far I've found a handful of very repeatable sections that all drop frames in Emby but do not in other media players. They also do not drop using Emby with an external video player setup. Just the Emby stock player.
rbjtech 5341 Posted January 31, 2024 Posted January 31, 2024 9 hours ago, fcorona76 said: They all work incredibly well in Emby using the stock settings on the shield after a factory reset. My receiver and TV handled all of the audio formats just fine from every one of them. But not all of my media is having a problem either. So far I've found a handful of very repeatable sections that all drop frames in Emby but do not in other media players. They also do not drop using Emby with an external video player setup. Just the Emby stock player. ok - so it is a reasonable known fact that Exoplayer is far less tolerant of corrupt frames than say VLC, but the fact your setup plays the demo files without issue - suggest to me there is nothing wrong with your setup, nor emby (in playing non-corrupt files that is ..). If you have a repeatable section that always drops frames, then maybe extract just that section (5-10 seconds worth) and post here or via pm (use mkvtoolnix etc). It's possible that in doing so, you fix the issue (as it will re-write the frames) but if that's the case, then a remux on the full file may fix it anyway. 1
fcorona76 3 Posted January 31, 2024 Author Posted January 31, 2024 1 hour ago, rbjtech said: ok - so it is a reasonable known fact that Exoplayer is far less tolerant of corrupt frames than say VLC, but the fact your setup plays the demo files without issue - suggest to me there is nothing wrong with your setup, nor emby (in playing non-corrupt files that is ..). If you have a repeatable section that always drops frames, then maybe extract just that section (5-10 seconds worth) and post here or via pm (use mkvtoolnix etc). It's possible that in doing so, you fix the issue (as it will re-write the frames) but if that's the case, then a remux on the full file may fix it anyway. See attached clip. I encoded this segment a dozen ways. This clip is using the settings as shown in the attached screen shots for the video and it's what I have used for all of my Bluray collection for some time. It works well for me and my old eyes. If I encode this movie with no audio I get NO stutter. If I encode this movie downmixed to stereo I get NO stutter. Audio is just passthrough so I can't really adjust anything there other than re-encode. I'm currently running this segment through in x264, x265, 10bit, various profiles, etc to see if anything changes. Let me know if you have the same dropped frames, or none at all. I appreciate any help in solving this. 0_stutter_fcorona76_clip1.mkv
rbjtech 5341 Posted January 31, 2024 Posted January 31, 2024 (edited) I concur that its not happy and stuttering (not constantly but mid way through the clip) on all but the very first audio track. 1st Track seems ok to me. Stat's for Nerds below - this is via Direct File Access on a Shield 2019 Pro with AVR passthrough. It's likely the hevc encoding settings that Exo/Shield combo does not like (likely the hevc profile) - because it plays fine via Emby Theatre .. 4th track - AC3 Stereo - stutter 3rd AC3 Track - Stutter 2nd track - THD - Stutter Emby Theatre on PC - no issues on any track (but no passthrough) ... Edited January 31, 2024 by rbjtech
rbjtech 5341 Posted January 31, 2024 Posted January 31, 2024 (edited) To Add - this is a Main L5.2/High HEVC file - there really is no need for this @ 1080p at this bitrate - Main L4 is more than sufficient. So maybe have a play around with those - or use the Auto defaults that handbrake gives you as a test. edit - Yes, handbrake on 'Auto' using HEVC 8Bit @ 1080p uses Main L4 Main - so try that with your bespoke encoding params - you may need High to cover some of those options. Where did the bespoke parameters come from ? Edited January 31, 2024 by rbjtech
fcorona76 3 Posted January 31, 2024 Author Posted January 31, 2024 14 minutes ago, rbjtech said: To Add - this is a Main L5.2/High HEVC file - there really is no need for this @ 1080p at this bitrate - Main L4 is more than sufficient. So maybe have a play around with those - or use the Auto defaults that handbrake gives you as a test. edit - Yes, handbrake on 'Auto' using HEVC 8Bit @ 1080p uses Main L4 Main - so try that with your bespoke encoding params - you may need High to cover some of those options. Where did the bespoke parameters come from ? The extra settings came from perceived increases to quality with lower video bit rates. It may be due to the video but if I encode that exact segment with no audio it plays smooth as butter. With audio UnRaid spikes at about 15mbps up to the shield so I highly doubt it's a bandwidth problem. I did more searching for x/h265 problems with Emby for android and found a lot more similar problems going years back.
rbjtech 5341 Posted January 31, 2024 Posted January 31, 2024 (edited) Agree it's not bandwidth - frankly, using 50% of the available bitrate for Audio seems a strange choice, but that's your prerogative I have 4K 120Mbit/sec with 3 or 4 HD Audio tracks (TrueHD+DTS-HD etc) playing on the Shield and they all play perfectly - so as I said above - I suspect it's your encoding settings/hevc profile interlaced with audio that Exo does not like. As a next step, I'd suggest using one of the hevc Handbrake templates with Audio passthrough - and see if it still does it - I suspect it won't - and you then have your answer... I'll leave it for emby to answer, but I highly suspect Google/Emby are unlikely to 'fix' an issue based on an edge case caused by bespoke encoding params.. Edited January 31, 2024 by rbjtech
fcorona76 3 Posted January 31, 2024 Author Posted January 31, 2024 7 minutes ago, rbjtech said: Agree it's not bandwidth - frankly, using 50% of the available bitrate for Audio seems a strange choice, but that's your prerogative I have 4K 120Mbit/sec with 3 or 4 HD Audio tracks (TrueHD+DTS-HD etc) playing on the Shield and they all play perfectly - so as I said above - I suspect it's your encoding settings/hevc profile interlaced with audio that Exo does not like. As a next step, I'd suggest using one of the hevc Handbrake templates with Audio passthrough - and see if it still does it - I suspect it won't - and you then have your answer... I'll leave it for emby to answer, but I highly suspect Google/Emby are unlikely to 'fix' an issue based on an edge case caused by bespoke encoding params.. I'm old. My ears are far better than my eyes! I'll try a prepackaged HB profile for x265 and see what happens...I do not want to re-encode an entire library because a player is broken. 1
rbjtech 5341 Posted January 31, 2024 Posted January 31, 2024 (edited) 10 minutes ago, fcorona76 said: I'll try a prepackaged HB profile for x265 and see what happens...I do not want to re-encode an entire library because a player is broken. It may also be worth trying the Android app (sideloaded) - that may process things differently vs the AndroidTV App ? https://emby.media/emby-for-android.html Edited January 31, 2024 by rbjtech
signde 26 Posted January 31, 2024 Posted January 31, 2024 Feel free to boo me out of the room but I was curious so I tried the sample. Shield TV Pro 2019 Emby Android TV - stuttery Plex - plays fine Amazon Fire Stick 4K Max 2023 Emby Android TV - plays fine Plex - plays fine All were direct play, my AVR showed full passthrough audio. 2 1
rbjtech 5341 Posted January 31, 2024 Posted January 31, 2024 14 minutes ago, signde said: Feel free to boo me out of the room .. We have no reason to do that. Thanks for taking the time! I don't work for Emby, I'm just trying to help as well So yes, it may well be a 'Shield/Exo/Emby App/hevc profile' combo problem indeed if other hardware plays it just fine. I'll try the Android (non TV) App on the Shield Pro myself later - should have tried that when I tested first time .. 1
fcorona76 3 Posted February 1, 2024 Author Posted February 1, 2024 12 hours ago, rbjtech said: It may also be worth trying the Android app (sideloaded) - that may process things differently vs the AndroidTV App ? https://emby.media/emby-for-android.html I've done that and there was no improvement using the latest Android build direct from Emby. 1
