richenginner 2 Posted January 27, 2024 Posted January 27, 2024 EMBY does not recognize series, emby does not recognize network connected drives i need only replace T1 for SEASON 1? how to refresh changes?
Luke 42184 Posted January 27, 2024 Posted January 27, 2024 HI there, how are your files named and organized? How did you setup the libraries? What folders did you add in Emby library setup?
richenginner 2 Posted January 29, 2024 Author Posted January 29, 2024 On 1/27/2024 at 6:34 PM, Luke said: HI there, how are your files named and organized? How did you setup the libraries? What folders did you add in Emby library setup? in TV SHOW
Luke 42184 Posted January 29, 2024 Posted January 29, 2024 3 hours ago, richenginner said: in TV SHOW @richenginnerCan you please provide more information than that? HI there, how are your files named and organized? How did you setup the libraries? What folders did you add in Emby library setup?
richenginner 2 Posted January 29, 2024 Author Posted January 29, 2024 2 minutes ago, Luke said: @richenginnerCan you please provide more information than that? HI there, how are your files named and organized? How did you setup the libraries? What folders did you add in Emby library setup? i changed to mix content, and renaming using format S01E01 and it's works. i need rename 190TB of content thanks emby ¬¬
richenginner 2 Posted January 29, 2024 Author Posted January 29, 2024 3 minutes ago, richenginner said: i changed to mix content, and renaming using format S01E01 and it's works. i need rename 190TB of content thanks emby ¬¬ ohh additional, emby need change "T1" or somewhere name for "Season 1" Thanks emby.
richenginner 2 Posted January 30, 2024 Author Posted January 30, 2024 here, but i have another problem, emby not recognize drives attachet to windows for example emby not accept local address for example: D:\HOME CLOUD\SERIES\ANIMADOS
Luke 42184 Posted January 30, 2024 Posted January 30, 2024 What makes you think it's not recognizing the drives?
richenginner 2 Posted January 31, 2024 Author Posted January 31, 2024 On 1/29/2024 at 8:27 PM, Luke said: What makes you think it's not recognizing the drives? i connected this drives to my PC But EMBY do not recognize X:\HOME CLOUD\SERIES\ANIME simply NOT APPEAR. EMBY ONLY RECOGNIZE drives in network with this format \\Plexrich\49tb\HOME CLOUD\SERIES\ANIME in PLEX recognize drives attached to pc in certain cases when pc have problems to locate a pc in network. Thank you very much. hard to configure...
Luke 42184 Posted February 1, 2024 Posted February 1, 2024 What exactly makes you think that Emby doesn't recognize it? Yes you've kept saying that repeatedly, however I'm asking you to describe what exactly you mean. Thanks.
richenginner 2 Posted February 6, 2024 Author Posted February 6, 2024 I FIXED the problem: 1. Emby only recognize SEASON 1 not T1, Not Temporada 1, etc. 2. Emby only recognize S01E1 not 1x01 not 1x02, etc. 3. Emby requires precision isn't smart to detect for names, emby require PRECISION. 4. Anyway... rename all your series. Thanks! PD. not show covers in some cases i need upload manually.
tedfroop21 89 Posted February 6, 2024 Posted February 6, 2024 1 hour ago, richenginner said: I FIXED the problem: 1. Emby only recognize SEASON 1 not T1, Not Temporada 1, etc. 2. Emby only recognize S01E1 not 1x01 not 1x02, etc. 3. Emby requires precision isn't smart to detect for names, emby require PRECISION. Not because its what they want ----- its because that's how it matches to metadata on all the metadata servers.......... Plus if you read and follow this you can get all your movies named so they are identified correctly as well.
Luke 42184 Posted February 6, 2024 Posted February 6, 2024 Temporada 1 is supported as a season folder name.
richenginner 2 Posted February 6, 2024 Author Posted February 6, 2024 2 hours ago, Luke said: Temporada 1 is supported as a season folder name. not work for me, i changed all names only for emby, in plex works fine
Luke 42184 Posted February 6, 2024 Posted February 6, 2024 11 minutes ago, richenginner said: not work for me, i changed all names only for emby, in plex works fine How are the files named and organized?
