tsunami1701 6 Posted January 21, 2024 Posted January 21, 2024 Hi there, I have a movie with 2 audio tracks: italian and english. The italian track is out of sync but only when the movie is played in Emby; I tried to play the movie with VLC and other players and the track is on sync. Thanks! Davide These are the movie data: These are the stats for nerds for the italian track These are the nerd stats for the english track
Luke 42184 Posted January 21, 2024 Posted January 21, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
tsunami1701 6 Posted January 22, 2024 Author Posted January 22, 2024 Hi there, here is the server log I've started to play the movie with the italian track (the one out of sync) on 2024-01-22 19:23 for about 3 minutes, then I've played the same movie from the beginning with the english track for 3 minutes and then again 3 minutes from the beginning with italian track and 3 minutes with the english track. I attach even the direct stream log but this is generated only when i play the movie with the english track. Thanks! embyserver.txtffmpeg-directstream-00a7e09e-1c5d-4c22-807d-669c11b86f77_1.txtffmpeg-directstream-00a7e09e-1c5d-4c22-807d-669c11b86f77_12.txt
Luke 42184 Posted January 22, 2024 Posted January 22, 2024 Are you able to try Edge and see how that compares?
visproduction 328 Posted January 22, 2024 Posted January 22, 2024 (edited) ffmpeg log shows on 44 Mhz aac codec English uses Timebase 1/48000, but the Italian audio is encoded at 48 Mhz aac and uses ffmpeg Timebase 1/90000. See: https://stackoverflow.com/questions/43333542/what-is-video-timescale-timebase-or-timestamp-in-ffmpeg/ This ffmpeg auto settings, different for 44.1Mhz vs. 48MHz audio, might be the cause of the sync issue after ffmpeg encoding. Edited January 22, 2024 by visproduction 1
