flic 13 Posted January 21, 2024 Posted January 21, 2024 The Play Speed in the setting reset to Normal after it was changed to something else like 1.25 Very annoying when you start to watch a series at 1.25 speed then after playing 1 episode, it reset back to Normal at the next one So, let's say I'm far away from the computer and having to come up and manually change back the play back speed to 1.25 Would it be possible to store the selected Speed in the user configuration file and use that selected speed from now on and never reset it back to Normal automatically ? I would add the same request for the CC (only when the CC are set to Off) but lets not put too much on your plate for today  Thanks in advance Â
Luke 42235 Posted January 21, 2024 Posted January 21, 2024 HI, yes this question has come up before and is possible for future updates. Thanks.
flic 13 Posted February 16, 2024 Author Posted February 16, 2024 I think there were TWO updates and this is still not done?? Look, this is not a feature request No, the solution is to COMMENT ONE LINE OF CODEÂ in the PLAY media procedure ex. play_speed := 1;Â // 1=Normal if you comment that line in the code, the play speed will stay at what ever the user changed it to and thats what people want why not do it asap and be done with it and then focus on improving emby with new features...
