quickmic 1709 Posted January 23, 2024 Posted January 23, 2024 (edited) Did you watch content while the sync should have been happening? Or was the screeensaver active on the box? ...looking for a pattern... Maybe you could send me another log with Kodi debug mode enabled, but please via PM. Kodi debug log could include your private API key for Emby server. Edited January 23, 2024 by quickmic
Kylev2142 6 Posted January 23, 2024 Author Posted January 23, 2024 yes. for both the movies and episodes but the movies work and episoded don't. even now 12+ hours later True Detective S04E01 hast synced to kodi but in that time another movie has been picked up by radarr, imported and synced to the emby and koid libraries with no interference from me
quickmic 1709 Posted January 23, 2024 Posted January 23, 2024 As mentioned, the only odd I can see is, that Emby server removed the same episode after adding it: 2024-01-22 22:20:25.190 Debug LibraryMonitor: New file refresher created for /volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1.mkv 2024-01-22 22:20:25.524 Debug LibraryMonitor: New file refresher created for /volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1.nfo 2024-01-22 22:20:25.524 Debug LibraryMonitor: New file refresher created for /volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1-thumb.jpg.part 2024-01-22 22:20:25.862 Debug LibraryMonitor: New file refresher created for /volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1-thumb.jpg 2024-01-22 22:21:25.191 Info LibraryMonitor: Season 4 (/volume1/data/media/tv/True Detective/Season 4) will be refreshed. 2024-01-22 22:21:25.409 Debug App: Refreshing Episode /volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1.mkv due to configured automatic refresh interval 2024-01-22 22:21:25.409 Debug App: Running FFProbeProvider for /volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1.mkv 2024-01-22 22:21:25.409 Info MediaProbeManager: ProcessRun 'ffprobe' Execute: /var/packages/EmbyServer/target/bin/ffprobe -i file:"/volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1.mkv" -threads 0 -v info -print_format json -show_streams -show_chapters -show_format -show_data 2024-01-22 22:21:25.191 Info LibraryMonitor: Season 4 (/volume1/data/media/tv/True Detective/Season 4) will be refreshed. 2024-01-22 22:21:25.409 Debug App: Refreshing Episode /volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1.mkv due to configured automatic refresh interval 2024-01-22 22:21:25.409 Debug App: Running FFProbeProvider for /volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1.mkv 2024-01-22 22:26:03.892 Debug BaseItem: Removed item: /volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1.mkv 2024-01-22 22:26:03.892 Info App: Removing item from database, Type: Episode, Name: Part 1, Path: /volume1/data/media/tv/True Detective/Season 4/S04E01 - Part 1.mkv, Id: 31859 Look at the last line from Emby's log. Did you manually remove the episode again after adding? I see the removed item Id incoming on Kodi, but couldn't be remove it cause it was never downsynced in the first place.
Kylev2142 6 Posted January 23, 2024 Author Posted January 23, 2024 the file is still sitting on the drive exactly as it was when i copied it there. wierd because the episode is still in embys library, so its trying to remove it even though the files still there and its still in the library
