Allstar86 8 Posted January 19, 2024 Posted January 19, 2024 Hello, on my Zidoo Z9X Pro the automatic change to 24 Hz does not work. HDR10 and also DV works, but the refresh rate remains at 60 Hz. If I use the internal Zidoo player, this works without any problems. In the playback settings, I have checked the box that the player should switch to 24 Hz normally. Is this an error? Can this be fixed?
Luke 42244 Posted January 20, 2024 Posted January 20, 2024 Hi, what version of the Emby app are you running?
Allstar86 8 Posted January 20, 2024 Author Posted January 20, 2024 I have the latest beta version from the playstore. I don't know which number exactly, I only downloaded it on Thursday when the player arrived.
ebr 16337 Posted January 20, 2024 Posted January 20, 2024 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Allstar86 8 Posted January 21, 2024 Author Posted January 21, 2024 8 hours ago, ebr said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Are there differences between the Android and Android TV version? And are they both visually the same?
ebr 16337 Posted January 21, 2024 Posted January 21, 2024 Hi. They are different apps with mostly the same functionality. Are you able to try it?
ALD76 26 Posted January 21, 2024 Posted January 21, 2024 I believe this is a limitation of the Zidoo boxes and AFR only works with its native player.
invisiblescrat 4 Posted January 22, 2024 Posted January 22, 2024 Hi I have a zidoo uhd3000 with both emby android an android tv apps sideloaded. The automatic refresh is not working with either apps. it works with the native player and kodi but not with emby. 1
invisiblescrat 4 Posted February 4, 2024 Posted February 4, 2024 Hello emby dev’s anything on that? i am because of that issue obliged to watch things on my apple tv with infuse because on apple tv frame rate change but no hdr or dv. it works but it is annoying. Can’t we have an app on one device that does it all? i thought having emby premiere would free me of all those annoying things
ebr 16337 Posted February 4, 2024 Posted February 4, 2024 Hi. I believe that device only supports frame rate switching with its built in player.
