smecerb1 5 Posted January 19, 2024 Posted January 19, 2024 v 1.7.2 Q9FN, 2018 Seek bar does not work. Skip back and foward work only by buttons. 2
FrostByte 5453 Posted January 20, 2024 Posted January 20, 2024 On the OSD you can't move the timeline forward or back using right/left on the directional button. You can select the timeline, but nothing happens when you click right/left. The only thing you can do is pause by clicking the Enter button. steps bring up OSD make sure the timeline is selected click right/eft on directional button 1
SamES 1084 Posted January 20, 2024 Posted January 20, 2024 9 hours ago, FrostByte said: On the OSD you can't move the timeline forward or back using right/left on the directional button. You can select the timeline, but nothing happens when you click right/left. The only thing you can do is pause by clicking the Enter button. steps bring up OSD make sure the timeline is selected click right/eft on directional button I can confirm this as well. 1
Luke 42239 Posted January 20, 2024 Posted January 20, 2024 OK this should be resolved in 1.7.3.. Thanks. 1
FrostByte 5453 Posted January 20, 2024 Posted January 20, 2024 2 hours ago, Luke said: OK this should be resolved in 1.7.3.. Thanks. Working here, thanks. 1
