JuJuJurassic 49 Posted January 19, 2024 Posted January 19, 2024 Hi All, I've triggered the live TV refresh guide, to update the Virtual TV plugin, but my question isn't about virtualTV. The help I've been getting says the database refresh is just taking a long time. I don't think I have a particularly large library, 6k films 23k TV shows. I set the database cache size to 2048 and the Analysis row limit at 400. The Emby server is running on a dedicated box, 4 users is the max it's ever had. 32 GB of Ram, Utilisation is low. There's lots of resources available Are there any settings I could change, then restart the refresh, that would speed up the process? Thanks
Luke 42184 Posted January 19, 2024 Posted January 19, 2024 HI there, let's look at an example: How to Report a Problem Thanks.
JuJuJurassic 49 Posted January 21, 2024 Author Posted January 21, 2024 I've downloaded the embyserver.txt just after I started the refresh, I'll leave it a day, then download it again and post it. The database refresh seems to be a known problem, as mentioned here It's not so much a diagnosis of is there a problem or not I'm after. My Emby server has lots of spare resources, I wanted to know if there are any parameters I could change that would help the database refresh speed up, then I could put them back to "normal" values after the refresh had completed. Thanks 1 1
JuJuJurassic 49 Posted January 29, 2024 Author Posted January 29, 2024 My servers have been running the live TV refresh for 1 week, 4 days, 9 hours. Well that's the uptime of the server, so it's about that give or take half an hour. I've attached the embyserver.txt files one at the start of the refresh, one from today. I've edited my domain name to <URL>.com. I'd like to know what operation it's performing and see if I can help it. Basically, it looks like my live TV refresh is broken. If there's anything else I can upload, please let me know, but it seems I'm not alone with this problem. Dibbles has it, as does another, as can be seen here It did a refresh when I started with Virtual TV, months ago and it worked fine, but doesn't seem to want to play now. Thanks Juju embyserver (11).txt embyserver (11) - Start of refresh.txt
Luke 42184 Posted January 29, 2024 Posted January 29, 2024 Hi, please try removing these plugins: 2024-01-21 07:23:07.300 Info App: Loading MovieThemeSongs, Version=1.7.5.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/moviethemesongs.dll 2024-01-21 07:23:07.300 Info App: Loading statistics, Version=3.0.10.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Statistics.dll 2024-01-21 07:23:07.300 Info App: Loading Emby.SecurityCams, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.SecurityCams.dll 2024-01-21 07:23:07.300 Info App: Loading DiskSpace, Version=1.0.6.1, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/DiskSpace.dll 2024-01-21 07:23:07.300 Info App: Loading ThemeSongs, Version=1.6.6.7, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/themesongs.dll 2024-01-21 07:23:07.300 Info App: Loading VirtualTV, Version=1.1.3.2, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/VirtualTV.dll 2024-01-21 07:23:07.300 Info App: Loading Emby.XmlTV, Version=1.1.4.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.XmlTV.dll 2024-01-21 07:23:07.300 Info App: Loading MovieThemeVideos, Version=1.7.5.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/MovieThemeVideos.dll 2024-01-21 07:23:07.300 Info App: Loading ThemeVideos, Version=1.7.5.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/ThemeVideos.dll 2024-01-21 07:23:07.300 Info App: Loading playback_reporting, Version=2.0.1.1, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/playback_reporting.dll 2024-01-21 07:23:07.300 Info App: Loading MediaBrowser.Plugins.TuneIn, Version=1.2.6.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/MediaBrowser.Plugins.TuneIn.dll Then restart the server and see how things compare.
JuJuJurassic 49 Posted January 30, 2024 Author Posted January 30, 2024 That fixed it Now to add each plugin and refresh again, to find the culprit. But I'll do that tonight, not in my "work" time. Thanks Juju
Solution JuJuJurassic 49 Posted January 30, 2024 Author Solution Posted January 30, 2024 Ok, so I cheated a bit and reloaded each of the plugins when I shoudl have been working..... No problems, they all loaded ok, with the exception of the Virtual TV plugin, which I'm waiting to get the correct version. So the problem is fixed. 1
