Kyrunner 86 Posted January 19, 2024 Posted January 19, 2024 In the settings for Emby for Kodi next gen under interface there is a setting for Extra Audio widget refresh what is this setting. there is also a setting for refresh skin on emby server connection does this need enabled
quickmic 1709 Posted January 19, 2024 Posted January 19, 2024 (edited) 2 hours ago, Kyrunner said: In the settings for Emby for Kodi next gen under interface there is a setting for Extra Audio widget refresh what is this setting. Can you post a screenshot. I don't have it on my dev version, maybe legacy. Quote there is also a setting for refresh skin on emby server connection does this need enabled No, it's a workaround. The default settings are fine for almost every use case. Edited January 19, 2024 by quickmic
Kyrunner 86 Posted January 19, 2024 Author Posted January 19, 2024 1 hour ago, quickmic said: Can you post a screenshot. I don't have it on my dev version, maybe legacy. No, it's a workaround. The default settings are fine for almost every use case.
quickmic 1709 Posted January 20, 2024 Posted January 20, 2024 5 hours ago, Kyrunner said: Thanks, I removed this option in 9.X cause the plugin detects the content type. However, this has to do with progress updates and widget/views refresh. (Custom) skins/skin helpers refreshes the lists based on events e.g. a Kodi scan event. There are two sorts of scans audio and video. If you don't enabled this option, audio views might not be updated.
