jaypee123 0 Posted January 18, 2024 Posted January 18, 2024 Hi I have a DS220+ DSM 7.2.1-69057 Update 3 and Emby 4.7.14.0 Issue I have found, if I change the remote port to 8097 (and restarting) it doesn't open when I try connecting my browser to that port with all the changes made in the Router. Also connecting locally to 8097 doesn't work either. Swap it back to 8096 and update my router (routing), no issues at all, both locally and remote. It's like there's something in the code somewhere not updating the port even though it shows in the system settings. Thanks in advance
Luke 42241 Posted January 18, 2024 Posted January 18, 2024 Quote Also connecting locally to 8097 doesn't work either. Hi, why do you think this would work? Changing the remote port doesn't impact the local port.
Luke 42241 Posted January 18, 2024 Posted January 18, 2024 Can you show us your port forwarding setup?
