mechguy 12 Posted January 17, 2024 Posted January 17, 2024 (edited) I am having a large numder of identifcaiton issues on shows. When I manually identify with the exact text in the folders name I get a match with the first show every time. I have named the show as they are named in my preferred metadata provider with the quality in [ ] e.g. "show name [1080p]". Even when I copy the entire name including the contents of [ ] into the manual identifcation it correctly matches with the first hit so why does the library scan not match up? This isn't a case of incorrect identifcation but a failure to do so at all. Edited January 17, 2024 by mechguy
Luke 42184 Posted January 17, 2024 Posted January 17, 2024 HI there, can you please provide a specific example: How to Report a Problem Thanks.
mechguy 12 Posted January 18, 2024 Author Posted January 18, 2024 (edited) 22 minutes ago, Luke said: HI there, can you please provide a specific example: How to Report a Problem Thanks. A show with the folder name "Aldnoah.Zero [1080p]". Matches perfectly when manually searched with this exact text. I am having this issue with about 50% of my library. Edited January 18, 2024 by mechguy
Luke 42184 Posted January 18, 2024 Posted January 18, 2024 OK, please attach the emby server log from when that was first imported: How to Report a Problem If you don't have that anymore, then please provide the emby server log the next time it happens, along with the example in question. Thanks.
mechguy 12 Posted January 18, 2024 Author Posted January 18, 2024 (edited) 43 minutes ago, Luke said: OK, please attach the emby server log from when that was first imported: How to Report a Problem If you don't have that anymore, then please provide the emby server log the next time it happens, along with the example in question. Thanks. Server log attached, it seems to be searching the show correctly ignoring the contents of [ ]. Edited January 18, 2024 by mechguy
Luke 42184 Posted January 18, 2024 Posted January 18, 2024 16 minutes ago, mechguy said: Server log attached, it seems to be searching the show correctly ignoring the contents of [ ]. embyserver.txt 147.6 kB · 0 downloads Are you sure that's from when it was first imported? That looks more like a metadata refresh.
mechguy 12 Posted January 18, 2024 Author Posted January 18, 2024 5 minutes ago, Luke said: Are you sure that's from when it was first imported? That looks more like a metadata refresh. I forced an import by removing and readding the show, is this sufficient? embyserver.txt
mechguy 12 Posted January 20, 2024 Author Posted January 20, 2024 @Lukehave you been able to glean anything from the latest log?
mechguy 12 Posted January 26, 2024 Author Posted January 26, 2024 Bumping this in case anyone can help?
Solution mechguy 12 Posted January 31, 2024 Author Solution Posted January 31, 2024 For anyone that comes accross this, I ended up switching from TVDB to TMDB for identification and refreshing metadata. 1
