1971camaroguy 32 Posted January 17, 2024 Posted January 17, 2024 I have some dvd's that aren't available on any other medium that I rip and watch through emby on an nvidia shield I purchased a dvd of Sri Ashish online, never heard of it and seemed interesting, (indonesian Superhero Movie) Rip it with makemkv and dropped it on the movie folder. I started watching it and it was stuttering every 5-10 seconds, pretty annoying. I started messing with frame rates and figured out the frame rate of the rip was 29.97 frame rate. I re-encoded it in 23.976 frame rate and started the movie again and fixed it, no stuttering. I've noticed this a lot on DVD's, would I need to go back into my movies and re-encode them? Or am I missing a setting in emby? Thanks again!
GrimReaper 4896 Posted January 17, 2024 Posted January 17, 2024 (edited) Are you using AndroidTV app or sideloaded standard Android app on your Shield? EIther way, under app settings>Playback tab>Tick "Enable display refresh rate switching", see how does it compare. Edited January 17, 2024 by GrimReaper
1971camaroguy 32 Posted January 17, 2024 Author Posted January 17, 2024 Oops I may be in the wrong section, I don't have anything side-loaded....just the android OS that came standard on the shield Sorry for the confusion
Luke 42243 Posted January 17, 2024 Posted January 17, 2024 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
