Kyrunner 86 Posted January 16, 2024 Posted January 16, 2024 Is Cinema mode broken? I enabled the checkbox in the settings, but I can’t get any trailers to play when the movie starts. on the Emby server I have Cinema mode enabled with the trailers plugin installed. KFE 8.2.15
quickmic 1709 Posted January 16, 2024 Posted January 16, 2024 Does Emby server (WebUI) play trailers before a movie starts?
Kyrunner 86 Posted January 16, 2024 Author Posted January 16, 2024 1 minute ago, quickmic said: Does Emby server (WebUI) play trailers before a movie starts? Yes
quickmic 1709 Posted January 16, 2024 Posted January 16, 2024 Which mode do you use in plugin? native or addon mode?
quickmic 1709 Posted January 16, 2024 Posted January 16, 2024 ok, I'll check but quite sure it works under "regular" conditions. Can you send me a kodi.log as well.
Solution quickmic 1709 Posted January 16, 2024 Solution Posted January 16, 2024 I take it back, seems to be a bug. I'll fix it in next version
Kyrunner 86 Posted January 16, 2024 Author Posted January 16, 2024 4 minutes ago, quickmic said: I take it back, seems to be a bug. I'll fix it in next version Thanks. Anyway you can have IMDb trailers play instead of the emby trailers plugin seems the IMDB trailers add on on Kodi play at 1080p and look great. the emby trailers plugin looks like they play in SD
Kyrunner 86 Posted January 27, 2024 Author Posted January 27, 2024 On 1/16/2024 at 7:34 AM, quickmic said: I take it back, seems to be a bug. I'll fix it in next version Has this been fixed in the 8.2.15 version or is available in 9.4.1
quickmic 1709 Posted January 27, 2024 Posted January 27, 2024 (edited) Yes it is fixed in 9.X versions. Currently I'm focusing on this version not on 8.X Edited January 27, 2024 by quickmic
