VegarHenriksen 0 Posted January 15, 2024 Posted January 15, 2024 Hello! Can anyone help me out with what css command to use to change the hover and selected color for the sidebar menu?
VegarHenriksen 0 Posted January 15, 2024 Author Posted January 15, 2024 The problem is that the original one has an !important tag .navMenuOption-selected { background-color: hsla(var(--theme-primary-color-hue),var(--theme-primary-color-saturation),var(--theme-primary-color-lightness),.2)!important;
arrbee99 1836 Posted January 15, 2024 Posted January 15, 2024 Does any of this help - Not sure what half of it does, but it seems to make (most) stuff red - /*Dark Red - #A30000;*/ /* ---------------------------------------------------------------------------------------------------- */ /* Overall Colour Scheme */ html:root { --mycolour: #A30000; } /*html:root { --myhighlight: #00A3A3; }*/ html:root { --myhighlight: white; } html:root { --theme-primary-color-hue: 0 !important; --theme-primary-color-saturation: 100% !important; --theme-primary-color-lightness: 32% !important; --theme-accent-text-color: var(--mycolour); --theme-primary-color-lightened: var(--mycolour); --theme-icon-focus-background: rgba(120, 120, 120, 0.2); }
VegarHenriksen 0 Posted January 15, 2024 Author Posted January 15, 2024 12 hours ago, arrbee99 said: Does any of this help No, but thanks
arrbee99 1836 Posted January 15, 2024 Posted January 15, 2024 Oh well, mine looks like this - but the trouble is the css I thought that was doing that doesn't actually seem to do anything and I can't find in my disorganised mess that does. So not much help, as usual.
beckfield 174 Posted January 16, 2024 Posted January 16, 2024 For the hover color, this seems to work: .navDrawerListItemBody:hover { background-color: red; } Haven't figured out the 'selected,' but you have a few choices for this in the Settings > Display > Accent Color option.
VegarHenriksen 0 Posted January 16, 2024 Author Posted January 16, 2024 removing "body" works - thanks .navDrawerListItem:hover { background-color: #1b1b1b !important; }
VegarHenriksen 0 Posted January 16, 2024 Author Posted January 16, 2024 (edited) Selected in red is an issue because of the !important tag when you use red as an accent Edited January 16, 2024 by VegarHenriksen
VegarHenriksen 0 Posted January 16, 2024 Author Posted January 16, 2024 Eh, I decided to just copy the replicate the design in Ombi
visproduction 335 Posted January 21, 2024 Posted January 21, 2024 .drawer-open .navDrawerListItemBody:hover { background-color: #517288; border-radius: 0.6em; }
VegarHenriksen 0 Posted February 3, 2024 Author Posted February 3, 2024 Got it .drawer-open .navDrawerListItem:hover { background-color: #1b1b1b !important; border-radius: 0.6em;} .listItem-hoverable:hover .listItem-content-bg::before { display: none !important;}
