slicedmass 6 Posted January 14, 2024 Posted January 14, 2024 I have an issue that happens randomly it seems. I have my user with "Hide this user from login screens when connected remotely" and then setup to allow pin on local network. The problem is on any of my 3 FireTV 4k max (gen 1) devices when i click my profile to login it will just login without asking for my pin (every 1 in 20 times or so). I used to think that maybe it was a timing thing with how long ago I logged in on my phone (which has the account saved and doesn't ask for any password or pin) or how long ago since logging in to a different or the same firetv but it happened this morning after 8 hours of not touching any device or app. Wondering if anyone has experienced this on any device?
ebr 16354 Posted January 14, 2024 Posted January 14, 2024 Hi. If you want to always require a password, check the box in the Startup Options to always require the password.
slicedmass 6 Posted January 14, 2024 Author Posted January 14, 2024 Never knew that option existed. I have enabled it so I will see if I ever have that issue again. Just weird it would ask for a password only like 1 in 20 times.
Luke 42290 Posted January 14, 2024 Posted January 14, 2024 Please let us know if this resolves your issue. Thanks.
