Bvaring 2 Posted January 13, 2024 Posted January 13, 2024 I moved the location of emby portable on my computer. emby server has been set to allow in the windows firewall and is running as before as service using nssm. I can access emby on my local network but not externally. I have emby premiere with emby connect. The mobile app says "Unable to Reach..emby". Logging in via app.emby.media shows the server but says we're unable to connect right now. Im runniing emby 4.17.14.0 on Windows 11 Pro. I have even tried disabling the windows firewall just to see if that is the what is blocking it but it still doesn't work. How can I find out if there is a problem with the emby connect system or with my subscription. Please help. Thanks, Brad embyserver.txt
Bvaring 2 Posted January 13, 2024 Author Posted January 13, 2024 I am using only http://. But also it doesn't work in the Android app anymore. When I login with my connect account in the alp it automatically shows my server as an option to connect to with any info or configuration. Not it does show the server I can select but it does not connect. I have even tried wiping it all out and starting a fresh emby portable launch bur Sam's problem. I know something is being recognized because the app now shows my new emby server named after I set up this fresh new one. It displayed somehow automatically it got that much info but no connection, can't connect. The screen shot show the older server and the new server in the app. That updated by only logging in.
pwhodges 2023 Posted January 13, 2024 Posted January 13, 2024 Just now, Bvaring said: I am using only http://. But are you checking that the browser doesn't change this to https:// off its own bat? Paul
Luke 42184 Posted January 13, 2024 Posted January 13, 2024 I've merged your posting back into here to avoid having the same conversation in mulitple places. 1
Luke 42184 Posted January 13, 2024 Posted January 13, 2024 I would try doing a new server connection by manually entering the ip address.
Bvaring 2 Posted January 13, 2024 Author Posted January 13, 2024 Yes I am checking that. My Edge changes it but my Brave is configured to not upgrade url to https. But it doesn't work in the app either where the server info I populated automatically when I login to my connect account. The attached screen shows the local and remote address so it did connect enough to get my Wan IP
Bvaring 2 Posted January 13, 2024 Author Posted January 13, 2024 I renewed my old ddns and it works without port mapping perfectly. I wonder what changed but I'm good as long as this works.
Luke 42184 Posted January 14, 2024 Posted January 14, 2024 5 hours ago, Luke said: I would try doing a new server connection by manually entering the ip address. Did you ever try this?
Solution Bvaring 2 Posted March 8, 2024 Author Solution Posted March 8, 2024 Sorry I'm late. It all works now with Emby Connect, no ddns, not port forwarding or anything needed. I just started the entire process from the bottom up yet again and it worked this time. Too bad my primary hard drive went out about 2 weeks later. Thankfully I have a backup just need to get a new drive for the working copy. Tks 1
