Varg 1 Posted January 11, 2024 Posted January 11, 2024 Like the title is saying I have the following countless errors in my log: Emby check for plugin updates failed and Emby Guide Data Installation Failed. Everything seems to be working like it should but what can I do to resolve these errors? embyserver.txt
Abobader 3484 Posted January 11, 2024 Posted January 11, 2024 Hello Varg, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Varg 1 Posted January 11, 2024 Author Posted January 11, 2024 20 minutes ago, Luke said: Hi, are you using a vpn? No, I'm not using a VPN, never did on my PC. I'm on the latest Windows 10 version btw.
Luke 42184 Posted January 12, 2024 Posted January 12, 2024 Do you have any security software that could be blocking the outgoing request? The same thing is happening on metadata requests to omdbapi.com
Varg 1 Posted January 12, 2024 Author Posted January 12, 2024 6 minutes ago, Luke said: Do you have any security software that could be blocking the outgoing request? The same thing is happening on metadata requests to omdbapi.com I'm only using the standard Windows Security app. In Firefox I use uBlock Origin and Privacy Badger but I have both disabled for the Emby server website.
Luke 42184 Posted January 15, 2024 Posted January 15, 2024 Hi, are you still having an issue with this or has it cleared itself up?
Varg 1 Posted January 15, 2024 Author Posted January 15, 2024 9 hours ago, Luke said: Hi, are you still having an issue with this or has it cleared itself up? Yes, I'm still having the same issues although everything plays normally and subtitles are also being shown normally. 1
