blackrob12!! 0 Posted January 7, 2024 Posted January 7, 2024 Hello, I'm currently having this issue. Is updating the only fix?
Luke 42239 Posted January 7, 2024 Posted January 7, 2024 @blackrob12!! Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. Thanks!
AP123 13 Posted January 8, 2024 Posted January 8, 2024 22 hours ago, blackrob12!! said: Hello, I'm currently having this issue. Is updating the only fix? If you don’t want to/can’t update you can also download the subtitle srt files and add them to the movie folder. I use subscene.com. Then you want to make sure you name the SRT file properly so it automatically gets detected as the default subtitle option. For example, if you want subtitles for the movie Edge of Tomorrow, you’ll want to name your srt file Edge of Tomorrow.eng.default.srt and it will automatically play as the default subtitle option.
blackrob12!! 0 Posted January 8, 2024 Author Posted January 8, 2024 Sorry for the later reply. tracking i will give it a try. I tried open subtitles but it didnt work.
