Jlwhite04 0 Posted January 5, 2024 Posted January 5, 2024 Hello, I am also experiencing m3u timeout issues. the latest time out occured while using VLC external player option. But the same issue occurs with the native exoplayer as well. The issue occurs wtih Emby for Android 3.3.53 and Embyatv 2.0.93g. When i run the stream though xciptv exoplayer the stream continues to play, the stream might pause momentarily but will continue. I would like for the same to occur when using emby. Can you assist? embyserver (2).txt
Luke 42241 Posted January 6, 2024 Posted January 6, 2024 @Jlwhite04 what exactly happens when you try to play in Emby?
Jlwhite04 0 Posted January 6, 2024 Author Posted January 6, 2024 video play will just stop. for example this morning the screen appeared to have froze, However the progress bar appeared to continue to iterate. If the stream is disrupted from the source, I would exepct to have to restart when transcoding, but for direct play i would play to continue when stream resumes from source.
Luke 42241 Posted January 18, 2024 Posted January 18, 2024 hi @Jlwhite04are you still having an issue with this?
