Nate8727 9 Posted October 19, 2013 Posted October 19, 2013 I recently had trouble getting about 600 movies to show up in the MB3 library, and I've found a fix from different sites. I thought it was a permission issue at first, but that didn't seem to solve the problem. If you're getting "access denied" in the MB3 logs, then perform the following registry edit: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Systemcreate or modify 32-bit DWORD: LocalAccountTokenFilterPolicyset the value to: 1 Problem solved.
CWNashvegas 170 Posted October 19, 2013 Posted October 19, 2013 It allows one to keep UAC enabled on a machine but still have Windows allow admin rights to pass through on a remote connection. A value of 0 strips admin rights from remote connections, a value of 1 passes them through (provided that the connecting account has admin privileges - it doesn't grant extra rights to non-admin accounts). 1
Nate8727 9 Posted October 19, 2013 Author Posted October 19, 2013 I'm not sure exactly, as none of the sites gave an answer. I tried it though and it worked, and others reported it working also.
Nate8727 9 Posted October 19, 2013 Author Posted October 19, 2013 It allows one to keep UAC enabled on a machine but still have Windows allow admin rights to pass through on a remote connection. A value of 0 strips admin rights from remote connections, a value of 1 passes them through (provided that the connecting account has admin privileges - it doesn't grant extra rights to non-admin accounts). Thanks!
CWNashvegas 170 Posted October 19, 2013 Posted October 19, 2013 Thanks! You're welcome. I generally advise against applying fixes without knowing what they do. You can often track down the function of registry keys by searching in the Microsoft KB, if a Google search doesn't point you there. This particular fix has been around since Vista.
ebr 16354 Posted November 24, 2013 Posted November 24, 2013 Is this done on the originating machine or the machine that contains the shares?
