Max6x6x 2 Posted January 2, 2024 Posted January 2, 2024 I'm having the same issue  Google chromecast 4k with the emby server on a Synology DS218+ (6gb ram) any thoughts? ffmpeg-transcode-05a666fd-7822-4de4-905a-ab5ae78ff8dd_1.txt
Luke 42244 Posted January 2, 2024 Posted January 2, 2024 @Max6x6x Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Â
Max6x6x 2 Posted January 2, 2024 Author Posted January 2, 2024 (edited) Hi @Luke, Â On the chromecasts i have the standard emby app available on the playstore on the chrome cast is that not the correct one? Â from the link you've added I'm redirected to "Emby for Android"Â and the page says it's not compatible with the google chromecast device Edited January 2, 2024 by Max6x6x
Luke 42244 Posted January 14, 2024 Posted January 14, 2024 On 1/2/2024 at 4:21 PM, Max6x6x said: Hi @Luke, Â On the chromecasts i have the standard emby app available on the playstore on the chrome cast is that not the correct one? Â from the link you've added I'm redirected to "Emby for Android"Â and the page says it's not compatible with the google chromecast device Hi @Max6x6xdid you try downloading and installing the armv7 apk?
Max6x6x 2 Posted January 14, 2024 Author Posted January 14, 2024 nope, i ordered now an usb -c hub with etherne port so i can add ethernet to the google chromecast 4k instead of using it with wifi. although the strange thing is that even episodes of friends in 720p (x264) are stuttering mainly because automatically they start with the quality at 80mbps and i have to change it to 1mbps (that's the video bitrate) to make them work properly (btw the chromecast 4k is a google TV device https://store.google.com/us/product/chromecast_google_tv?hl=en-US&pli=1)
