VicMoore 755 Posted January 12, 2024 Author Posted January 12, 2024 (edited) @kjhedgesIsn't that what it is doing? Sometimes I am a bit slow to pickup on what is being asked. Please explain in more detail what you want. Vic Edited January 12, 2024 by VicMoore
kjhedges 67 Posted January 12, 2024 Posted January 12, 2024 7 minutes ago, VicMoore said: @kjhedgesIsn't that what it is doing? Yes sorry, My mistake. I see the bottom scroll bar and thought.......... I should really check before posting. Sorry about that
TZTZoro 26 Posted January 12, 2024 Posted January 12, 2024 in this image the letters(on the right in the gray) are not clickable because of my scrollbar is in the way i can not use the top bar except the red help button
TZTZoro 26 Posted January 12, 2024 Posted January 12, 2024 I would recommend using relative units like % and em/rm instead of using px because of this ^ This seems to be a solution, i do not know which classes are needed exactly, i think this class="flex flex-direction-column flex-grow scrollY" and then you set for the scrolldiv the height to auto, but i would still recommend changing absolute values to relative, for example people with a high screen zoom benefit the most from it maybe some styling like this? it makes the buttons clickable #sideNode { background-color: #f0f0f0; color: #333; padding: 0.8em; overflow-y: auto; position: sticky; top: 0; right: auto; } #sideNode .side_item { padding: 5px 0; flex: 1; border-bottom: 0.125em solid #ddd; } #sideNode .side_item:hover { background-color: #e9e9e9; cursor: pointer; } 1
VicMoore 755 Posted January 12, 2024 Author Posted January 12, 2024 Thanks @kjhedgesI will make the changes. I am poor with units in CSS. That's why everything is in px. I guess I will now have to learn new tricks. Vic
TZTZoro 26 Posted January 12, 2024 Posted January 12, 2024 what is the latest code if you dont mind sharing? i can try and go over and create a version of styling and then you can use what you want @VicMooreor you got yourself a new challenge
TZTZoro 26 Posted January 12, 2024 Posted January 12, 2024 when loading data you are requesting the data using a specific user, now you grab the userid from the logged in user but that means you dont get acces to all content if you do not have acces to all content, is it possible to select from which user? from what i remember from the openapi.json there is not an endpoint to query to get all items no matter the user also for the music videos you are not using Recursive=true which is the cause for this screenshot i believe if you do not have acces to all folders in a library
VicMoore 755 Posted January 12, 2024 Author Posted January 12, 2024 @TZTZoroI will send you the new code in 10 minutes. Normally it's attached to the bottom of the first post. Vic 1
VicMoore 755 Posted January 12, 2024 Author Posted January 12, 2024 @TZTZoroThe code is below Vic PseudoTV.zip
VicMoore 755 Posted January 12, 2024 Author Posted January 12, 2024 @TZTZoroYou have made excellent points both about the USER and using Recursion. Give me a bit to think about them. Vic
VicMoore 755 Posted January 13, 2024 Author Posted January 13, 2024 @TZTZoroI removed recursion from the URL where I load Emby library data and returned that feature to the Filter. You now navigate through all of the folders. You were right, This is a better technique. As for the user. For simplicity Lets keep it the way it is for now. When the current code is solid and mature then we can add that feature. You mentioned that you were going to improve the styling (CSS). That would be great. CSS is my weak point (among many) and I would learn much from you. Vic
TZTZoro 26 Posted January 13, 2024 Posted January 13, 2024 (edited) @VicMoorei sent you a message about the styling so i wouldnt fill the forum with pictures here is for example music folders, theming should also kind of support dark themes: movies, the blue glowing ones being the selected ones, i am not yet sure about that, added a checkmark when an item has been played, moved the favorite icon: filters for so far i have done them tonight I might do some more if you want to follow emby's styling more it seems like the html structure and some other structures should be changed a bit from what i have seen in emby but i am not experienced with that Edited January 13, 2024 by TZTZoro
VicMoore 755 Posted January 13, 2024 Author Posted January 13, 2024 @TZTZoroWhat you did with CSS is just amazing. I am so impressed. I have two requests. The first is that with the theme I am using the text color for the light colored buttons is poorly visible. The text is difficult to see. The second is the border and caption color for folders. Could you possibly use an icon on the picture (like you did for favorites and Played)? I am going to spend hours learning CSS from you. Thank you so much. I will stop coding until you finish your changes. I love them all. Vic
TZTZoro 26 Posted January 13, 2024 Posted January 13, 2024 (edited) @VicMooreyou mean like this? unfortunately i do not really understand what you find difficult to see, which text A, this text? B, this text? i personally like the overlay over the title that the image kind of moves forward but i can understand why it looks bad/does not work C, you mean like this? (if the buttons are white on white i accidentally gave the wrong zip file) Edited January 13, 2024 by TZTZoro 1
VicMoore 755 Posted January 13, 2024 Author Posted January 13, 2024 (edited) Yes, exactly. Fantastic job. Let me know when you are finished. When you are done, I will add my few lines of added code and publish the total as the next plugin release. Vic P.S. Could you please make the background color for folders a color that is more pleasing. Edited January 13, 2024 by VicMoore
VicMoore 755 Posted January 13, 2024 Author Posted January 13, 2024 (edited) @TZTZorocan you put little icons on the tag and a genre captions (i don't know what they would be) to visually distinguish what these captions are. This is just an idea. What do you think? Is this reasonable? P.S. It doesn't bother me that the glow that circles a selected image, overlaps the name caption. I really like your changes. Edited January 13, 2024 by VicMoore
kjhedges 67 Posted January 13, 2024 Posted January 13, 2024 Looking good guys. I been working so not been about, but Im liking the improvements on the gui by you guys
VicMoore 755 Posted January 13, 2024 Author Posted January 13, 2024 @kjhedgesThanks for the kind words. Soon I hope to post the latest code. Vic 1
VicMoore 755 Posted January 13, 2024 Author Posted January 13, 2024 @TZTZoroAnything new to share? Tomorrow I would like to put together a new plugin release. We greatly appreciate your contributions. Vic
VicMoore 755 Posted January 14, 2024 Author Posted January 14, 2024 Everyone, below and in post 1 is the latest code that includes my code and @TZTZorocode. vic PseudoTV.zip PseudoTV.dll
TZTZoro 26 Posted January 14, 2024 Posted January 14, 2024 (edited) @VicMoore some mobile support added (tested on s20, +, ultra) filter section edited some more Edited January 14, 2024 by TZTZoro
VicMoore 755 Posted January 14, 2024 Author Posted January 14, 2024 (edited) @TZTZoroThis is so good. It's better than I expected. I will add my code into it and post it tonight. Thank you so much. You have made a great contribution to this project. Vic Please send me the latest code. Edited January 14, 2024 by VicMoore 1
TZTZoro 26 Posted January 14, 2024 Posted January 14, 2024 I sent it as a message to you so people dont get confused by the code sources
VicMoore 755 Posted January 14, 2024 Author Posted January 14, 2024 Everyone, the new code with all of @TZTZorocode is attached to POST 1. Vic
VicMoore 755 Posted January 14, 2024 Author Posted January 14, 2024 I just added the updated, to POST 1, the updated code from @TZTZoro There is a bug in the JS code when you delete the last channel. I will fix it today. Vic
