mickle026 653 Posted January 7, 2024 Posted January 7, 2024 (edited) 1 hour ago, VicMoore said: @TZTZoroand @kjhedgesI think I found the problem. Try the code below; Vic PseudoTV.dll 204.5 kB · 2 downloads @VicMoore I have not tried this plugin, but in an earlier post it was mentioned that it is working on third time brings back problems I had with one of my plugins. Only one of the three pages would work. If this is the same kind of error..... Here is a snippet of how to load the page that works in all 3 instances. In a browser there are 3 versions of a page cached with emby (UI Quirks), they dont all update. You have to change the way you render the html page in the first place in the js original discussion with devs here define(["loading","require", "jQuery", "globalize", "emby-checkbox", "emby-select", "emby-linkbutton", "emby-input", "emby-button"], function (loading) { return function (page) { }); } }); Edited January 7, 2024 by mickle026
VicMoore 755 Posted January 7, 2024 Author Posted January 7, 2024 yes you are right. I removed the button. All the button did was reload the html page. I will look deeper. Vic
VicMoore 755 Posted January 7, 2024 Author Posted January 7, 2024 Thanks @mickle026I will try your suggestion. Vic
VicMoore 755 Posted January 7, 2024 Author Posted January 7, 2024 @mickle026I greatly enjoyed reading your forum posts where you and @chefdiscussed the problem. I am not the sharpest knife in the draw, so I need to clarify my understanding of your recommended solution. First, use "view" instead of "document" when using "getElementById". Second, I need to organize my JS code as below: define(['globalize', 'loading', 'appRouter', 'formHelper', 'emby-input', 'emby-button', 'emby-checkbox', 'emby-select'], function (globalize, loading, appRouter, formHelper) { 'use strict'; function (loading) { // my javascript code here return function (view, params) { view.addEventListener('viewshow', function () { // my javascript code here }); }; ); }); Are my assumptions correct? Vic
VicMoore 755 Posted January 7, 2024 Author Posted January 7, 2024 @mickle026I would be very grateful if you would explain what worked for you. Vic
VicMoore 755 Posted January 8, 2024 Author Posted January 8, 2024 @mickle026I have been experimenting. I changed the core "document.getElementId" to "view.querySelector". I don't know if this helped yet. @TZTZorocould you try the plugin below and let me know if it loads OK? Vic PseudoTV.dll 1
TZTZoro 26 Posted January 8, 2024 Posted January 8, 2024 @VicMoore Still the same error about the configurationpage.js, installed the plugin with a reboot without the plugin just to rule that out and refreshed the page and opened the page through the ui multiple times just in case, no luck
VicMoore 755 Posted January 8, 2024 Author Posted January 8, 2024 Does it help to reload the page several times?
TZTZoro 26 Posted January 8, 2024 Posted January 8, 2024 Nope, i still get the same errors as in this post 8 hours ago, TZTZoro said: I am using firefox Uncaught (in promise) TypeError: nameArray is undefined activeChannels http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:2965 getActiveChannels http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:2963 init http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3033 fillTunerHostInfo http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3074 reload http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3062 promise callback*reload http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3058 <anonymous> http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3255 onNewViewDisplayed http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 onViewChange http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 promise callback*onViewChange http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 loadView http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 promise callback*ViewManager.prototype.loadView/< http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 promise callback*ViewManager.prototype.loadView http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 loadContentUrl http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 loadContentUrl http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*loadContentUrl http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 initRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*initRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*handleRoute/</< http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleSignedInResult http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*AppRouter.prototype.handleSignedInResult/< http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleSignedInResult http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleConnectionResult http://host1:8096/web/modules/common/baseapprouter.js?v=4.8.0.66:1 handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 dispatch http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 replace http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 start http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 page http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 start http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*appRouter.start http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 onAppReady http://host1:8096/web/app.js?v=4.8.0.66:1 promise callback*onAppReady http://host1:8096/web/app.js?v=4.8.0.66:1 promise callback*start http://host1:8096/web/app.js?v=4.8.0.66:1 <anonymous> http://host1:8096/web/app.js?v=4.8.0.66:1 <anonymous> http://host1:8096/web/app.js?v=4.8.0.66:1 configurationpage:2965:25 getActiveChannels http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3000 InterpretGeneratorResume self-hosted:1465 AsyncFunctionNext self-hosted:852 (Async: async) init http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3033 InterpretGeneratorResume self-hosted:1465 AsyncFunctionNext self-hosted:852 (Async: async) fillTunerHostInfo http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3074 reload http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3062 (Async: promise callback) reload http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3058 <anonymous> http://host1:8096/web/configurationpage?name=pseudotvconfigjs&v=4.8.0.66:3255 onNewViewDisplayed http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 onViewChange http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 (Async: promise callback) onViewChange http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 loadView http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 (Async: promise callback) loadView http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 (Async: promise callback) loadView http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 loadContentUrl http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 loadContentUrl http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 (Async: promise callback) loadContentUrl http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 initRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 (Async: promise callback) initRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 (Async: promise callback) handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 (Async: promise callback) handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleSignedInResult http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 (Async: promise callback) handleSignedInResult http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleSignedInResult http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleConnectionResult http://host1:8096/web/modules/common/baseapprouter.js?v=4.8.0.66:1 handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 dispatch http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 replace http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 start http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 page http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 start http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 (Async: promise callback) start http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 onAppReady http://host1:8096/web/app.js?v=4.8.0.66:1 (Async: promise callback) onAppReady http://host1:8096/web/app.js?v=4.8.0.66:1 (Async: promise callback) start http://host1:8096/web/app.js?v=4.8.0.66:1 <anonymous> http://host1:8096/web/app.js?v=4.8.0.66:1 <anonymous> http://host1:8096/web/app.js?v=4.8.0.66:1 Uncaught TypeError: slideeElement is null init http://host1:8096/web/modules/scroller/smoothscroller.js?v=4.8.0.66:1 value http://host1:8096/web/modules/emby-elements/emby-scroller/emby-scroller.js?v=4.8.0.66:1 loadView http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 promise callback*ViewManager.prototype.loadView http://host1:8096/web/modules/viewmanager/viewmanager.js?v=4.8.0.66:1 loadContentUrl http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 loadContentUrl http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*loadContentUrl http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 initRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*initRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*handleRoute/</< http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleSignedInResult http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*AppRouter.prototype.handleSignedInResult/< http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleSignedInResult http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 handleConnectionResult http://host1:8096/web/modules/common/baseapprouter.js?v=4.8.0.66:1 handleRoute http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 dispatch http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 replace http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 start http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 page http://host1:8096/web/modules/pagejs/page.js?v=4.8.0.66:1 start http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 promise callback*appRouter.start http://host1:8096/web/modules/approuter.js?v=4.8.0.66:1 onAppReady http://host1:8096/web/app.js?v=4.8.0.66:1 promise callback*onAppReady http://host1:8096/web/app.js?v=4.8.0.66:1 promise callback*start http://host1:8096/web/app.js?v=4.8.0.66:1 <anonymous> http://host1:8096/web/app.js?v=4.8.0.66:1 <anonymous> http://host1:8096/web/app.js?v=4.8.0.66:1 smoothscroller.js:1:11126 edit: i also tried brave and edge and both give similar looking result, didnt check the console
TZTZoro 26 Posted January 8, 2024 Posted January 8, 2024 (edited) wait, i got a different result @VicMoore apiclient stopping message listener ScheduledTasksInfo apiclient.js:1:19501 Sending web socket message: ScheduledTasksInfoStop apiclient.js:1:18797 ====== params = Object { name: "pseudotvconfig" } configurationpage:3070:17 ++++++++++ tuner host configuration = Object { Type: "pseudotvtuner", ImportFavoritesOnly: false, PreferEpgChannelImages: true, PreferEpgChannelNumbers: false, AllowHWTranscoding: true, AllowMappingByNumber: true, TunerCount: 0, ProviderOptions: "{}", DataVersion: 0 } configurationpage:2888:21 ++++++++++ ProviderOptions = Object { } configurationpage:2899:17 === User id = 386464fde02c4ef2b8600eed9fca828b configurationpage:2838:17 === Server info = Object { ManualAddress: "http://host1:8096", ManualAddressOnly: true, IsLocalServer: true, DateLastAccessed: 1704672385019, LastConnectionMode: 2, Type: "Server", Name: "Pieter2", Id: "b205f5ba1d97485790f1f3853f4a3771", UserId: "386464fde02c4ef2b8600eed9fca828b", AccessToken: null, … } configurationpage:2840:17 === Current User Name = TZTZoro configurationpage:2842:17 === accessToken = null configurationpage:2845:17 ===== currentViews = Array(6) [ {…}, {…}, {…}, {…}, {…}, {…} ] configurationpage:2852:17 ================================= configurationpage:2759:17 >>>> Get Live Channels configurationpage:2760:17 >>>> live channels = Array(5) [ {…}, {…}, {…}, {…}, {…} ] configurationpage:2767:17 >>>>> providerOptions = Object { } Edited January 8, 2024 by TZTZoro
TZTZoro 26 Posted January 8, 2024 Posted January 8, 2024 Empty, and the html is also empty <div id="masterContainer"> <div id="helpNode" class="helpNode"> </div> <div id="titleNode" class="titleNode"> </div> <div id="buttonNode" class="buttonNode"> </div> <div class="scrollDiv"> <div id="pageNode" class="pageNode"> </div> </div> <div id="modalNode" class="modalNode"> </div> </div>
VicMoore 755 Posted January 8, 2024 Author Posted January 8, 2024 OK - I see whats happening - I am going to change one line of code and the program should come up OK Vic
VicMoore 755 Posted January 8, 2024 Author Posted January 8, 2024 I made a mistake. The plugin corrects the mistake. Vic PseudoTV.dll
TZTZoro 26 Posted January 8, 2024 Posted January 8, 2024 i get an ui, the first time i could do stuff but it didnt seem like it saved anything, the selecting content did not work like movies and tvshows after a server reboot the first UI shows without content and channels and the buttons dont do anything 1
VicMoore 755 Posted January 8, 2024 Author Posted January 8, 2024 we are making progress - I have to help my wife for a bit. I will write you a response in 1 hour. thanks so much for your help. vic
mickle026 653 Posted January 8, 2024 Posted January 8, 2024 sorry for not replying sooner - busy day The solution I posted was for the page caching 3 times as an emby gui quirk - that code I posted solves that The uncaught promise is something is either not returned from your api, or there is an error in the information returned or is isnt parsed correctly, ie received into the js properly. ie, a function call to the api or c# code - either fails or fails to return properly I will install this plugin and see if I can help
VicMoore 755 Posted January 8, 2024 Author Posted January 8, 2024 (edited) @mickle026The latest code is attached belowPseudoTV.zip With help from @TZTZoroI may have the problem solved. I followed your proposal and isolated all of the DOM nodes where I attach code with the JS and created references to those nodes using "view.querySelector" rather than "Document.getElementById" and the problem went away. I may still have a problem. I will find out tomorrow when more testing can be done. I would greatly appreciate you looking at the code. @mickle026you have taught me so much today. Thank you very much. Vic PseudoTV.dll Edited January 8, 2024 by VicMoore
VicMoore 755 Posted January 8, 2024 Author Posted January 8, 2024 @TZTZoroI fixed the problem you pointed out in your last post. I hope everything works OK now. You have made a real contribution to this project. Thank you very much. Vic
mickle026 653 Posted January 8, 2024 Posted January 8, 2024 7 minutes ago, VicMoore said: @mickle026The latest code is attached belowPseudoTV.zip With help from @TZTZoroI may have the problem solved. I isolated all of the DOM nodes where I attach code with the JS and created references to those nodes using "view.querySelector" rather than "Document.getElementById" and the problem went away. I may still have a problem. I will find out tomorrow when more testing can be done. I would greatly appreciate you looking at the code. @mickle026you have taught me so much today. Thank you very much. Vic PseudoTV.dll 204.5 kB · 0 downloads Thanks @VicMoore I will look at the code as soon as I have time. Pretty swamped this week though. So not really any idea when it will be. 1
VicMoore 755 Posted January 8, 2024 Author Posted January 8, 2024 @mickle026I understand. You have already been a great help. Vic
TZTZoro 26 Posted January 8, 2024 Posted January 8, 2024 7 hours ago, VicMoore said: @mickle026The latest code is attached belowPseudoTV.zip With help from @TZTZoroI may have the problem solved. I followed your proposal and isolated all of the DOM nodes where I attach code with the JS and created references to those nodes using "view.querySelector" rather than "Document.getElementById" and the problem went away. I may still have a problem. I will find out tomorrow when more testing can be done. I would greatly appreciate you looking at the code. @mickle026you have taught me so much today. Thank you very much. Vic PseudoTV.dll 204.5 kB · 1 download Using this version the UI looks like this Only the first channel button works in the first image, all the other buttons do not work(i only didnt try to update the epg), the other 5 channels are from a different source i think but they do have logos 1
kjhedges 67 Posted January 8, 2024 Posted January 8, 2024 @VicMoore I see progress has been made. I created a single channel and this populated as it should do. I was able to view the Live TV Channel I created and the EPG was complete too. I was not able to edit the current channel I created though once it was created. I also presume that the settings and help buttons are currently not active 1
VicMoore 755 Posted January 8, 2024 Author Posted January 8, 2024 @TZTZoroand @kjhedgesthanks so much for the testing. Yes, we are making progress. Please copy me the browser console when the plugin stops working. I want to see the error message. Vic
