softworkz 5133 Posted January 3, 2024 Posted January 3, 2024 Did you try this? 6 hours ago, softworkz said: You can work around this by first removing the plugin dll. Then restarting the server, then shutting down again and only then add the new plugin dll. In other words: let the server start once without any version of the plugin.
VicMoore 755 Posted January 3, 2024 Author Posted January 3, 2024 @softworkzYes I did... I followed your exact words. Vic
TeamB 2440 Posted January 3, 2024 Posted January 3, 2024 if you are changing the name change the GUID as well 1
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 @TeamBThanks for the info. Yes, I did change the GUID. Vic
softworkz 5133 Posted January 4, 2024 Posted January 4, 2024 Here you go... PseudoTV.zip I have no idea how it is supposed to work, but it seems to do as it should (at least the UI)
Luke 42250 Posted January 4, 2024 Posted January 4, 2024 1 hour ago, TeamB said: if you are changing the name change the GUID as well The guid is only used to match up your plugin with the plugins in the plugin catalog. Changing that association is generally the only reason to change the guid value.
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 WOW.. @softworkzthanks so much. Vic
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 It works perfectly - I will add my JS changes tonight. Tomorrow I will start testing everything. I am also coding a new GUI. Thanks so much for your help. Vic 1
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 I just uploaded the latest code. Vic
Dibbes 515 Posted January 4, 2024 Posted January 4, 2024 4 minutes ago, VicMoore said: I just uploaded the latest code. Vic I'm currently having some scanning/refresh issues (See vTV thread), but once that is resolved, I'll definitely have a go with this...
Dibbes 515 Posted January 4, 2024 Posted January 4, 2024 23 hours ago, GrimReaper said: Since you're in "Top Contributor" member group, you don't have time limit on editing your posts (Regulars have 3 hrs, Rookies have 15 minutes), just edit first post in any topic you've started and you can append/modify Topic Title as well, as it's considered a part of it. That's why! Now I get why I couldn't edit a topic in another forum anymore after trying some troubleshooting stuff
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 (edited) Good morning @Dibbestake your time. I am still improving the code. vic Edited January 4, 2024 by VicMoore 1
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 (edited) My bug fix caused another. I am fixing the main problem and will update the plugin later this morning Vic Edited January 4, 2024 by VicMoore
GrimReaper 4906 Posted January 4, 2024 Posted January 4, 2024 41 minutes ago, Dibbes said: That's why! Now I get why I couldn't edit a topic in another forum anymore after trying some troubleshooting stuff 1
Dibbes 515 Posted January 4, 2024 Posted January 4, 2024 @GrimReaperI haven't been that active ever since my kids were born a few years back. Difficult to keep up with those kind of changes... Thanks for sharing! 1 1
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 The major problem is fixed. I am still testing. I just uploaded the current plugin. Vic
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 OK, I found the problem, fixed it, and uploaded the plugin. It's now ready for testing. Vic
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 I know the channels in the GUI are getting out of sync with the channels in the tuner platform. I am working on the fix now. Vic
Oracle 86 Posted January 4, 2024 Posted January 4, 2024 Awesome work on this project, @VicMoore I'll test around with this tonight and into this weekend and provide some feedback.
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 Well I said this earlier, I have found the bug and fixed it. The plugin should now stay in sync with the tuner. The only requirement is that the channel names must be unique. I will remove this restriction later. Vic
VicMoore 755 Posted January 4, 2024 Author Posted January 4, 2024 Hello @Oraclenice to meet you. I would greatly appreciate your help testing. The code is very fresh and I am still fixing big bugs. I think I have most sorted out. Let me know what you find and what you would like the GUI to be. Vic
Oracle 86 Posted January 4, 2024 Posted January 4, 2024 You got it, buddy. I'll let you know what happens. Happy to help where I can.
VicMoore 755 Posted January 5, 2024 Author Posted January 5, 2024 I just uploaded updated code. It's starting to get stable. Later today I will explain what changed. Vic
VicMoore 755 Posted January 6, 2024 Author Posted January 6, 2024 I just uploaded the latest plugin. All known bugs are fixed vic
TZTZoro 26 Posted January 7, 2024 Posted January 7, 2024 It isnt working for me on 4.8.0.66 The red "Click to start EmbyTV" button shows up less then a second and is then out of frame and i got one time it like this: After making it clickable i just get a blank page: PseudoTV, Version=1.0.1.870
