jriker1 21 Posted January 1, 2024 Posted January 1, 2024 Playing LiveTV on Emby. Audio keeps cutting out for a second ever 20 seconds or so. Any idea what's going on? Picture stays flawless just the audio keeps blanking. ffmpeg-directstream-d773fc76-1257-48e5-b7e7-bebd157b7099_1.txt embyserver (8).txt
jriker1 21 Posted January 1, 2024 Author Posted January 1, 2024 Note remembered it's usually asked for. i tried LiveTV thru the Android app instead of AndroidTV. Audio doesn't cut out.
Luke 42178 Posted January 2, 2024 Posted January 2, 2024 22 hours ago, jriker1 said: Note remembered it's usually asked for. i tried LiveTV thru the Android app instead of AndroidTV. Audio doesn't cut out. Great, thanks. Are you happy continuing to use that?
ebr 16305 Posted January 2, 2024 Posted January 2, 2024 On 12/31/2023 at 10:42 PM, jriker1 said: Audio doesn't cut out. Hi. Is it playing exactly the same way or is the other app converting something?
jriker1 21 Posted January 11, 2024 Author Posted January 11, 2024 On 1/1/2024 at 7:59 PM, Luke said: Great, thanks. Are you happy continuing to use that? No, mentioned this in another thread but when you pause LiveTV and want it to buffer for a bit when you try to jump forward in the cached content it keeps going back to the start of where you paused it. Example. I am watching the news and want to watch the weather. But not sure when it will be on. So I pause it and go do something. Come back 20 minutes later and hit play. Try jumping forward or fast forwarding and keeps going back to when I paused it.
jriker1 21 Posted January 11, 2024 Author Posted January 11, 2024 On 1/2/2024 at 8:26 AM, ebr said: Hi. Is it playing exactly the same way or is the other app converting something? I can check but my issue watching TS based content was showing direct play and apparently wasn't since when I told it to direct play TS materials started working again. Thinking maybe what's being displayed isn't accurate? Not sure if the two android apps would play the Emby LiveTV content differently.
Luke 42178 Posted January 11, 2024 Posted January 11, 2024 4 minutes ago, jriker1 said: No, mentioned this in another thread but when you pause LiveTV and want it to buffer for a bit when you try to jump forward in the cached content it keeps going back to the start of where you paused it. Example. I am watching the news and want to watch the weather. But not sure when it will be on. So I pause it and go do something. Come back 20 minutes later and hit play. Try jumping forward or fast forwarding and keeps going back to when I paused it. Ok well good news, that will change soon.
jriker1 21 Posted May 25, 2024 Author Posted May 25, 2024 Thought I'd follow up on this. Don't use Emby much for live TV as the cut out of audio is annoying but watching it now and cuts out every 10 seconds. Here's the fully part. The audio cuts every 10 seconds when watching the news, but when it switches to commercials doesn't do it.
Luke 42178 Posted May 28, 2024 Posted May 28, 2024 On 5/24/2024 at 11:15 PM, jriker1 said: Thought I'd follow up on this. Don't use Emby much for live TV as the cut out of audio is annoying but watching it now and cuts out every 10 seconds. Here's the fully part. The audio cuts every 10 seconds when watching the news, but when it switches to commercials doesn't do it. Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks.
JuJuJurassic 49 Posted May 29, 2024 Posted May 29, 2024 Does this relate to my problem with live tv stopping after 3 seconds?
Luke 42178 Posted June 2, 2024 Posted June 2, 2024 On 5/29/2024 at 1:08 PM, JuJuJurassic said: Does this relate to my problem with live tv stopping after 3 seconds? Hi, we'll help you in your topic. Thanks.
jriker1 21 Posted March 16, 2025 Author Posted March 16, 2025 (edited) On 5/27/2024 at 9:52 PM, Luke said: Hi. Can you try searching for our standard android app (Just "Emby" on Amazon and "Emby for Android on Google) on the same device's app store and see how that compares? Thanks. Sorry for the delay. Thought I responded to this. Seems the Android phone version works with the test I did so far however the Android TV version doesn't always do this either but does a lot. Thought I mentioned or maybe was a different thread, there is no caching of live content if you like pause, and no way to go back a few minutes of a show you are watching using this version of the app not an ideal solution. JR Edited March 16, 2025 by jriker1
Luke 42178 Posted March 17, 2025 Posted March 17, 2025 Quote Seems the Android phone version works with the test Hi, and you tried this on the TV device?
jriker1 21 Posted March 17, 2025 Author Posted March 17, 2025 Yes one that just says Emby and on the NVidia Shield. If not mentioned when i record TV in Emby it's clean other than occasionally it doesn't record the full show but most of the time it does and no audio cutout. 1
