sfatula 208 Posted December 31, 2023 Posted December 31, 2023 Emby Server 4.7.14.0. Been running for a very long time perfectly. But today noticed not a single live channel! I restarted emby and the server log is attached. Apparently, this get is failing at the end of the log: GET https://host2/v1.1/lineups/USA-ECHOST-DEFAULT/channels?enhancedCallSign=true Not sure what host2 is but still, is likely cause. Don't know what host2 refers to, so, can't manually fix it if it's a DNS issue. Any ideas? This is very bad for me, NCAAF! Is there a way out of this? embyserver.txt
Solution sfatula 208 Posted December 31, 2023 Author Solution Posted December 31, 2023 I should have searched more first. The Dish Network guide went away for the region I was using, so, changed to a nearby one and all is back. Sorry for the post though maybe it will help someone else. 1
sfatula 208 Posted December 31, 2023 Author Posted December 31, 2023 (edited) Yeah, but, while I can do that, and the guide populates for all 14 days, there are 0 scheduled recordings. I have 2 guide sources: 1. Emby Guide Data for my zip code, which I did not change and 2. A Dish Network semi local guide that allows me to pull in guide data for one channel missing from the Emby Guide Data It pulls the guide data in when refreshing the guide, but nothing is scheduled. I've even temporarily deleted the extra guide, just using the Emby Guide Data. All the channels (but one) are still mapped of course. Edited December 31, 2023 by sfatula
sfatula 208 Posted December 31, 2023 Author Posted December 31, 2023 Looks like all my scheduled recordings are hosed. There is no channel info in them if you look at the series. If I populate the channel, then the schedule shows up. So, something messed that up. Maybe an ID changed? This is bad as you can never create them for all shows since many are not active this season, maybe they are summer shows or the season already ended making this a terrible task. Maybe a backup might help
Spaceboy 2573 Posted December 31, 2023 Posted December 31, 2023 any change to the epg will require schedule recordings to be remapped to the new epg. there is no way of avoiding this. its one of the reasons why i prefer to maintain epg and m3u combos externally to emby because you can make changes to the lineup in an external tool but emby still sees the same set of channels delivered to it
sfatula 208 Posted January 7, 2024 Author Posted January 7, 2024 On 12/31/2023 at 3:24 AM, Spaceboy said: any change to the epg will require schedule recordings to be remapped to the new epg. there is no way of avoiding this. its one of the reasons why i prefer to maintain epg and m3u combos externally to emby because you can make changes to the lineup in an external tool but emby still sees the same set of channels delivered to it Yeah, but fortunately restoring the previous days backup was good enough and restored them all. But that is bad the way it works, what a pain (otherwise) to try and recreate a years worth of timers. 1
