jriker1 21 Posted December 30, 2023 Posted December 30, 2023 (edited) I had to wipe and redo my NVidia Shield Pro 2019 the other day. Movies still play. My recorded shows on Emby still play. I have some shows I download in MP4 format that just spin when i try to play them. They were fine before. Looks like the version of the client installed is 2.0.99g beta. Says it's direct playing But on screen it's just a big blue spinner. Files would be in: \\vmce\d$\DuckieTVShows\General Hospital\ from a log perspective since I have multiple copies of General Hospital shows both downloaded mp4 and Emby thru TV. Logs seem to show something about transcoding and something about changing packet size over and over. Happening now in every file of General Hospital in that folder. embyserver (6).txt ffmpeg-directstream-346698f1-f958-47d5-a993-415e8580d0eb_1.txt generalhosptailmetadata.txt Edited December 30, 2023 by jriker1
Luke 42244 Posted December 30, 2023 Posted December 30, 2023 HI, since you're on the beta server, can you upload to the latest build and see how things compare? thanks.
jriker1 21 Posted December 30, 2023 Author Posted December 30, 2023 (edited) Sure, question while I'm at it. How do you restart Emby? I ask as it sounds weird but a while ago you could restart Emby thru the web interface. Now it just has an option to Shutdown the Server. Not restart it, shutdown. Frequently if I restart the Emby server physically it will still tell me to restart Emby to finish updates afterwards so am sometimes wondering when it wants to restart to apply the updates what that process should be. Edited December 30, 2023 by jriker1
Luke 42244 Posted December 30, 2023 Posted December 30, 2023 Self-restarting isn't supported when you're running as a windows service, so that's why you're not seeing it.
jriker1 21 Posted December 30, 2023 Author Posted December 30, 2023 On Version 4.8.0.65 beta now and same. Rebooted as well for good measure but no joy.
Luke 42244 Posted December 30, 2023 Posted December 30, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
jriker1 21 Posted December 30, 2023 Author Posted December 30, 2023 (edited) Sure I can install that again. If you want to check here is the file itself: https://www.dropbox.com/scl/fi/s6vn5zjksw14r1hdktpum/General-Hospital-S61E51.mp4?rlkey=1o8zqz1kzj7rbr8r6ekb5l10x&dl=0 Note almost thought I was running the Android app. Acts a lot like it where you click once to the right on the remote and Emby moves like 4 clicks. Edited December 30, 2023 by jriker1
js28194 42 Posted December 30, 2023 Posted December 30, 2023 (edited) You mentioned you redid your Sheild Pro. I have found BEFORE anything is that I mounted my remote shares in Sheild first from the sheild settings menu. Connecting it to Sheild before any apps such as Kodi and Emby, I have never had an issue. You may want to try that. Also, on my server, I just choose to add libraries with IP address instead of name. So instead of \\Server\TV\ShowName I choose \\192.168.xxx.xx\TV\Showname and it is no more problems with SMB v1, v2 , v3 etc. I do not know if this your issue. Edited December 30, 2023 by js28194
jriker1 21 Posted December 30, 2023 Author Posted December 30, 2023 Thanks. With the IP vs Server name been set this way for many years so won't go down that rabbit hole. Plus being Windows network IP can be detremental with logging into shares and the like not using the name. With the remote shares, all my files are on multiple servers so would be odd that this one doesn't work. All my machines are on the same network domain and Emby in Windows is running with a domain admin account.
jriker1 21 Posted December 30, 2023 Author Posted December 30, 2023 (edited) 27 minutes ago, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Tried the Emby App for Android and it worked immediately with the General Hospital files. Side note looks like your icons for Android are the same with the two apps. May want to tweak that as hard to tell them apart until you open them. Remeber the two apps had similar icons but the Emby image was smaller on one. Edited December 30, 2023 by jriker1
Luke 42244 Posted December 30, 2023 Posted December 30, 2023 15 minutes ago, jriker1 said: Tried the Emby App for Android and it worked immediately with the General Hospital files. Side note looks like your icons for Android are the same with the two apps. May want to tweak that as hard to tell them apart until you open them. Remeber the two apps had similar icons but the Emby image was smaller on one. Thanks! Are you happy continuing to use that?
ebr 16337 Posted December 30, 2023 Posted December 30, 2023 36 minutes ago, jriker1 said: looks like your icons for Android are the same with the two apps Hi. Look closely...
ebr 16337 Posted December 30, 2023 Posted December 30, 2023 1 hour ago, jriker1 said: I have some shows I download in MP4 format that just spin when i try to play them Can you please play that item for a few seconds and then follow the instructions to send a log from the app?
jriker1 21 Posted December 30, 2023 Author Posted December 30, 2023 Log sent 5:39PM CST. Think the logged in user is syarbrou
ebr 16337 Posted December 31, 2023 Posted December 31, 2023 15 hours ago, jriker1 said: Log sent 5:39PM CST. Think the logged in user is syarbrou Thanks. Can you please attach the server log that goes with that playback?
jriker1 21 Posted December 31, 2023 Author Posted December 31, 2023 To late so I redid it. Should be a new file I had the app send you at 5:18PM EST. Attached is the server log. embyserver (7).txt
ebr 16337 Posted January 1, 2024 Posted January 1, 2024 Okay, this may be related to the beta server as ffmpeg is failing on these items.
Luke 42244 Posted January 6, 2024 Posted January 6, 2024 On 12/30/2023 at 4:48 PM, Luke said: Thanks! Are you happy continuing to use that?
Solution rbjtech 5344 Posted January 8, 2024 Solution Posted January 8, 2024 So the original container is TS - Transport Stream. If it worked before using Emby for AndroidTV, then it may simply be that you have not set the Emby App to allow direct playback of TS files (set in Playback) ... and thus it is transcoding them. Previously they likely direct played - which will be better quality anyway.
jriker1 21 Posted January 11, 2024 Author Posted January 11, 2024 On 1/5/2024 at 9:20 PM, Luke said: Not really. I was going to say yes but using LiveTV as well on the standard Android app isn't usable. Like if I pause livetv and then come back and want to jump forward a bit it won't let me. Keeps going back to the time I paused it.
jriker1 21 Posted January 11, 2024 Author Posted January 11, 2024 On 1/8/2024 at 10:52 AM, rbjtech said: So the original container is TS - Transport Stream. If it worked before using Emby for AndroidTV, then it may simply be that you have not set the Emby App to allow direct playback of TS files (set in Playback) ... and thus it is transcoding them. Previously they likely direct played - which will be better quality anyway. Bingo. Since I had to reinstall everything due to a weird network glitch on the Shield Pro I didn't recheck that setting. Thanks a lot!! 1 1
