arron1985 2 Posted December 29, 2023 Posted December 29, 2023 Hi guys just wondering if someone can help. I got my kids there own jvc google tv for xmas with the hope of them using emby on there new TV's. I found the emby app on the google playstore and installed it too both TV's. When i try to put in the ip address nothing happens it just stays on the manually log in to server page. I have also tried emby connect and it comes up with the name of my server but says unable to connect. I have 2 firesticks 4 phones and laptops working fine with no problems. This is the first time a device is unable to connect. I hoping i can be an easy fix. Thanks
ebr 16337 Posted December 29, 2023 Posted December 29, 2023 These TVs are on the same LAN as the server? 37 minutes ago, arron1985 said: When i try to put in the ip address Exactly how are you inputting it? The fact the server doesn't come up automatically is an indication of something on your network possibly blocking.
arron1985 2 Posted December 29, 2023 Author Posted December 29, 2023 Using the Lan address. I have tried it with http:// and also with out. I have also tried the remote address. what's the best way to find out if its being block as everything normally works really well with emby and its the first problem i have had connecting to it. Thanks
ebr 16337 Posted December 29, 2023 Posted December 29, 2023 If there is a "Send Logs" button on the page where you end up after trying to log in, hit that and then tell me exactly when you did. Thanks.
arron1985 2 Posted December 29, 2023 Author Posted December 29, 2023 There isn't no send logs unfortunately. Sorry for being a pain. Here a few pictures of what's I have on the tv
js28194 42 Posted December 29, 2023 Posted December 29, 2023 I'm shocked that JVC still makes stuff. Must be in Europe or Asia. On the local LAN on a computer web broswer or phone web browser can you goto ip address of emby server? xxx.xxx.xxx.xxx:8096? Replace xxx's with your server ip address.
arron1985 2 Posted December 29, 2023 Author Posted December 29, 2023 I'm in the UK. I have replaced them with my ip and it all it comes up with is error connecting to server. I have done it several times on other devices and this is the first time it doesn't work.
js28194 42 Posted December 29, 2023 Posted December 29, 2023 (edited) From your picture, it says logout of connect, which to me means you are connected already with Emby Connect (which I do not use)? I do not know if that is causing your issue. I can always recommend to either delete emby cachce, data and start over, or uninstall and reinstall. Emby on Android is really not any voodo magick, it just kinda works so I am sorry to hear you are having issues. Edited December 29, 2023 by js28194
js28194 42 Posted December 29, 2023 Posted December 29, 2023 Plus the only other thought I have is networking... Emby should self discover Emby Server and that fact you are having to put it in manually is a clue of something.
arron1985 2 Posted December 29, 2023 Author Posted December 29, 2023 I tried emby connect as the ip didn't work and it didn't see the server out of the box. It's an odd one because every device have running off my server works like a charm. Just these new tvs seem to not see the server. I'm out of ideas. Thanks for everyone help. If I find the problem I will let everyone know.
js28194 42 Posted December 29, 2023 Posted December 29, 2023 (edited) Ahhh, I do not think emby connect works as an IP.... I would delete data/cahce or uninstall and reinstall and let Emby self discover if you are on Local LAN. If Emby Server is remote location then that is a different solution... Emby Connect or port forwarding etc on your server network. Edited December 29, 2023 by js28194
arron1985 2 Posted December 29, 2023 Author Posted December 29, 2023 I will uninstall it and try again. My server is on the same network and emby should see it. Every other device I have works fine. I will have a play around again with both tvs and see how I get on. Will try again with a reinstall of the emby app on the tv.
Solution arron1985 2 Posted December 30, 2023 Author Solution Posted December 30, 2023 Hi everyone just an update. I found out the problem and it was network related. I had the kids tvs logged into the guest wifi on my router as it can have a time set to turn it off but I didn't realise that with guest wifi it doesn't allow devices to talk to other devices hence my problem with emby not finding my server. Thanks for everyone's help much appreciated you giving me your time. Thank you 1
