sundevil67 30 Posted February 10, 2025 Posted February 10, 2025 On 12/28/2023 at 3:25 PM, TeamB said: To use it install the plugin from the catalogue and look in the Schedule Tasks, there should be a new one. Source Code https://github.com/faush01/StrmExtract Is the plugin still up in the catalog? I can't seem to find it
TeamB 2440 Posted February 10, 2025 Author Posted February 10, 2025 37 minutes ago, sundevil67 said: Is the plugin still up in the catalog? I can't seem to find it yes it is there, under metadata
Steinus 1 Posted February 18, 2025 Posted February 18, 2025 On 2/11/2025 at 2:45 AM, TeamB said: yes it is there, under metadata Why might these plugins not be in the catalog? Even proxer and studio cleaner are not in the list
rbjtech 5345 Posted February 18, 2025 Posted February 18, 2025 4 minutes ago, Steinus said: Why might these plugins not be in the catalog? Even proxer and studio cleaner are not in the list In Plugins > Catalog - type CTRL + F in the browser and then type in the Plugin name (or part thereof) you wish to find. Agree the Plugins area should have a Search box but it does not.. If it's not in the Catalog, then you'll have to manually add the DLL provided by the Dev. Dev's may not want their plugins listed in the Catalog as this suggests they are somewhat 'supported' - when in truth, they are likely only supported 'best efforts or use at your own risk' - which as they are 'free' is 100% understandable. 1
horstepipe 423 Posted February 21, 2025 Posted February 21, 2025 On 2/9/2025 at 9:16 PM, TeamB said: it uses the refresh metadata function with the EnableRemoteContentProbe option set to true https://github.com/faush01/StrmExtract/blob/da1ce795093d27a00efa26ec1e37ec7312cc3fbd/StrmExtract/ExtractTask.cs#L91 thank you, but this parameter does not seem to be available via the API?
TeamB 2440 Posted February 21, 2025 Author Posted February 21, 2025 7 hours ago, horstepipe said: thank you, but this parameter does not seem to be available via the API? not sure, @Lukewill know if this is possible via a REST API call 1
Luke 42253 Posted February 21, 2025 Posted February 21, 2025 No, that param is not currently in the api. 1
RunAway189 0 Posted March 20, 2025 Posted March 20, 2025 @TeamBSorry for the OT but I'm desperately trying to adapt your plugin for jellyfin and I'm struggling a lot because I'm not a programmer. I'm almost about to give it up... Could you please give me any advice? Thank you in advance
Luke 42253 Posted March 20, 2025 Posted March 20, 2025 4 minutes ago, RunAway189 said: @TeamBSorry for the OT but I'm desperately trying to adapt your plugin for jellyfin and I'm struggling a lot because I'm not a programmer. I'm almost about to give it up... Could you please give me any advice? Thank you in advance HI, why not just use his plugin with Emby? 1
goin3d 4 Posted April 7, 2025 Posted April 7, 2025 Question, from what I can tell if I have a duplicate entry in my library such as a local tv episode, but then also a strm link the strm link doesn't get checked does it? Is that because metadata already exists for that library item?
TeamB 2440 Posted June 10, 2025 Author Posted June 10, 2025 On 6/9/2025 at 7:12 PM, Flippz said: For some reason its not catching all the strm files. Even in the same series and season it misses half of them. (season pack so theyr probably the same) The plugin just calls the internal core rescan metadata function with the probe external media flag set TRUE. You would have to check the Emby log file so see why Emby can't prob the metadata from the external link in the STRM file.
TeamB 2440 Posted June 11, 2025 Author Posted June 11, 2025 1 hour ago, Flippz said: All it seems to say is 2025-06-11 00:23:25.913 Info App: StrmExtract - Item dropped : It's a Fae, Fae, Fae, Fae World - /storage/symlinks/series/Lost Girl (2010) {imdb-tt1429449}/Season 01/Lost Girl (2010) - S01E01 - Its a Fae Fae Fae Fae World [Bluray-1080p Remux]-EPSiLON.strm - MediaBrowser.Controller.Entities.TV.Episode - 1 you could try turning on emby debug logging to see if it had any better into. playing the item
TeamB 2440 Posted June 12, 2025 Author Posted June 12, 2025 23 hours ago, Flippz said: Sadly no more info added with debug what happens when you play the item
svyaznoy362 17 Posted August 11, 2025 Posted August 11, 2025 Hi. Make it possible to choose which strm media libraries can be excluded.
wq2020wdm 0 Posted October 9, 2025 Posted October 9, 2025 It seems that it does not work properly on emby 4.9. After I run it, there are still many strm without media information. My emby version is 4.9.1.80.
wabisabi926 13 Posted October 13, 2025 Posted October 13, 2025 On 10/9/2025 at 10:41 AM, wq2020wdm said: 似乎在 emby 4.9 上无法正常工作。我运行之后,还有很多没有媒体信息的 strm 。我的 emby 版本是 4.9.1.80。 me too.Under the latest system, it can extract some parts, but most of the remaining parts fail to be extracted normally. Repeating the scheduled task doesn't work either.
wabisabi926 13 Posted October 16, 2025 Posted October 16, 2025 On 8/11/2025 at 10:14 PM, svyaznoy362 said: 你好。 可以选择可以排除哪些 strm 媒体库。 Currently, there is a new project called strmtool – you can give it a try.
wq2020wdm 0 Posted October 18, 2025 Posted October 18, 2025 On 10/16/2025 at 11:24 AM, wabisabi926 said: Currently, there is a new project called strmtool – you can give it a try. I can't find the Project. Could you give me the link?
wabisabi926 13 Posted October 20, 2025 Posted October 20, 2025 On 10/18/2025 at 10:59 AM, wq2020wdm said: I can't find the Project. Could you give me the link? https://github.com/jinlin-teck/strmtool
soderlund 113 Posted October 20, 2025 Posted October 20, 2025 (edited) There is also the StrmAssistant plugin, very feature rich! Can warmly recommend. Unfortunately with Emby v4.9.x he has made it a "PRO" edition and require a license.. But with v 4.8 it's an extremely handy tool for much more than just extracting media info! https://github.com/sjtuross/StrmAssistant Edit: Just found a fork of the light version that seems to be working pretty well on the latest beta. (no license) https://github.com/Swiftfrog/StrmAssistant Edited October 20, 2025 by soderlund91
soderlund 113 Posted October 20, 2025 Posted October 20, 2025 (edited) 24 minutes ago, soderlund91 said: There is also the StrmAssistant plugin, very feature rich! Can warmly recommend. Unfortunately with Emby v4.9.x he has made it a "PRO" edition and require a license.. But with v 4.8 it's an extremely handy tool for much more than just extracting media info! https://github.com/sjtuross/StrmAssistant Edit: Just found a fork of the light version that seems to be working pretty well on the latest beta. (no license) https://github.com/Swiftfrog/StrmAssistant Actually it seems like the original "Lite version" still works with the latest Emby release. https://github.com/sjtuross/StrmAssistant/releases/tag/v2.0.0.30 It did not, but see above, the fork seems to do the job Edited October 20, 2025 by soderlund91
wq2020wdm 0 Posted October 21, 2025 Posted October 21, 2025 21 hours ago, wabisabi926 said: https://github.com/jinlin-teck/strmtool thanks
sundevil67 30 Posted October 25, 2025 Posted October 25, 2025 Is the STRM & M3U file formats & syntax pretty similar among IPTV providers? After finally getting Emby working with the VOD stufff mostly (still not able to reliably update with new episodes but way closer than I've ever been), I'm really close to switching services as it's gone way downhill and shows no signs of getting better. I'm thinking most of the folks in here are using the same but wanted to check as this is the first I've used that I ever tried to plug into Emby.
HjanecksD03 2 Posted December 21, 2025 Posted December 21, 2025 I’ve been messing around with .strm files lately too. It’s a great way to keep the library clean, but it’s definitely a pain when you need to bulk edit the URLs or pull specific metadata out of them once they're already set up. If you’re looking to extract data from documents or notes you’ve kept about your stream sources, I actually found a handy little tool recently: https://wordimageextractor.com/. I used it to pull a bunch of reference images and link lists out of some old project docs I had saved—it’s much faster than opening every file manually if you're trying to reorganize your library assets. Are you trying to extract the URLs into a spreadsheet, or just trying to get Emby to read the metadata tags better?
