McMovies 7 Posted December 27, 2023 Posted December 27, 2023 (edited) hello, while watching a show, a user browsed the cast/crew, and accidentally clicked "got, it. never show this again" so now on, whenever while playing a movie, if clicked on the people, it is stopping the playback and displaying that people description. (hope i'm able to describe the problem, above.) how do i reset, so that user get the dialoge box if clicked on a people - that if the click this it will stop playback. Edited December 27, 2023 by McMovies typo
Luke 42244 Posted December 27, 2023 Posted December 27, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
Solution ebr 16337 Posted December 27, 2023 Solution Posted December 27, 2023 12 hours ago, McMovies said: how do i reset, so that user get the dialoge box if clicked on a people Hi. I'm afraid you would need to "clear data" on the app in the Android menus. This will reset all your settings to default.
McMovies 7 Posted December 29, 2023 Author Posted December 29, 2023 On 28/12/2023 at 02:01, ebr said: Hi. I'm afraid you would need to "clear data" on the app in the Android menus. This will reset all your settings to default. thanks, it worked. there wasn't much of a local setting so all good. 1
