skale 0 Posted December 27, 2023 Posted December 27, 2023 I am running emby on TrueNAS Scale. It runs fine when I open it through TrueNAS from a device on the network. The local ip of my server is 192.168.50.95, but the listed IP on the dashboard is 172.16.0.50. The ports are default 8096/8920. Attempting to connect to this ip does not work. So I changed the local IP in Server>Network to what the actual ip of my NAS is (192.xx...). This doesn't work either. I have tried different browsers, the windows app, web app, other devices on the network. Is there some setting in the TrueNAS app configuration I need to mess with? I have been searching for hours and it doesn't seem like anyone has had this problem.
Luke 42244 Posted December 27, 2023 Posted December 27, 2023 Quote So I changed the local IP in Server>Network to what the actual ip of my NAS is (192.xx...). This doesn't work either. Hi, why do you think this doesn't work?
skale 0 Posted December 27, 2023 Author Posted December 27, 2023 No VPN. Im not sure why it doesn’t work.
Luke 42244 Posted January 15, 2024 Posted January 15, 2024 Hi @skalewere you able to figure this out? What networking mode is the container set to, host or bridge?
