NitroNine 29 Posted December 26, 2023 Posted December 26, 2023 I don't know if I may be the only one, but I never care about the songs list appearing on top when going into an artist. It would be great if there was a away to either remove the songs section, or change the order so albums can be on the top? 3 4
Jägs 86 Posted December 26, 2023 Posted December 26, 2023 +1; I'm more interested in seeing albums first, too. In fact, it'd be great if songs / appears on would be a separate link (for the sake of loading time). I don't want to remove it altogether, as it is useful for seeing what songs they have on compilations, but that—to me, at least—is secondary to albums. 1 2
Luke 42245 Posted December 26, 2023 Posted December 26, 2023 HI ,yes this idea has come up before and is possible for future updates. Thanks.
user24 352 Posted December 26, 2023 Posted December 26, 2023 @NitroNine@Jägs Yes, you are not the only ones. I would also prefer Songs to be below Albums. I suspect that many Emby music fans would have large ALBUM focussed libraries rather than large SONG focussed libraries. For me the songs/albums order is the main aspect that I don't like on the Album Artist pages. Everything else is very good overall. (Possibly people that stream a lot of their music from online services, e.g. Spotify, Tidal, etc. would prefer songs first???) There is at least one way to set up Emby to show only Albums, but it would take a lot of work and you also lose much of the other good info. Essentially you could make the main Collection folder a defacto Album Artist Collection folder by assigning music Albums into individual Artist Collections. I was experimenting with this over Christmas and posted a suggestion here: Even though this is possible to set up, I still personally prefer the current Album Artist pages with all of the fields (Songs, Albums, Tags, Appears On, etc.) Maybe one day in the future we (or Emby) will be able to change the order to suit Album oriented libraries?!?!? 1 1
user24 352 Posted February 15, 2024 Posted February 15, 2024 @NitroNine@Jägs I've been researching and experimenting with this a bit more (on and off) over the last couple months. If you are using the web app you can use custom CSS to likely achieve a Music view that suits your needs.. It is possible to hide any sections that you don't want to see and also swap the order of those that you do want to see. Check out this thread for hiding Sections (thanks to @beckfield ) Check out this thread for changing the order of Sections: The various bits of CSS code should work for the latest stable Emby Version 4.8.1.0. 2 1
user24 352 Posted May 9, 2024 Posted May 9, 2024 (FWIW) Some more thoughts... There is a “3 dot” settings tab on RHS of the secondary menu of the top-level Album Artist/Artist/Composer pages that allows for changing the view settings of the current top-level page: This edit area could potentially also be a place to make global changes to the view of the underlying individual pages in a similar way. A new “Show Sections” option could work similarly to the “Show Fields” option that exists now: Having this "Show Sections" editing available individually for the respective Album Artist/Artist/Composer categories would give great flexibility by allowing three custom user-defined page views for the three categories. Combining the above show/hide options with the new drag and drop reordering in Emby 4.8.6.0 would be brilliant! 2 1
unisoft 355 Posted May 11, 2024 Posted May 11, 2024 On 09/05/2024 at 05:22, user24 said: (FWIW) Some more thoughts... There is a “3 dot” settings tab on RHS of the secondary menu of the top-level Album Artist/Artist/Composer pages that allows for changing the view settings of the current top-level page: This edit area could potentially also be a place to make global changes to the view of the underlying individual pages in a similar way. A new “Show Sections” option could work similarly to the “Show Fields” option that exists now: Having this "Show Sections" editing available individually for the respective Album Artist/Artist/Composer categories would give great flexibility by allowing three custom user-defined page views for the three categories. Combining the above show/hide options with the new drag and drop reordering in Emby 4.8.6.0 would be brilliant! Emby will need a preference and policy editor soon to set defaults for settings or enforce settings from the SERVER side for users.
user24 352 Posted May 11, 2024 Posted May 11, 2024 2 hours ago, unisoft said: Emby will need a preference and policy editor soon to set defaults for settings or enforce settings from the SERVER side for users. Emby's soon-to-be-announced secret new AI entity (codename: DR NUKEABLE) will handle it easily - think about it! 1
ginjaninja 605 Posted May 25, 2024 Posted May 25, 2024 On 26/12/2023 at 14:50, NitroNine said: I don't know if I may be the only one, but I never care about the songs list appearing on top when going into an artist. It would be great if there was a away to either remove the songs section, or change the order so albums can be on the top? I think when looking at an artist's page who is not an album artist, but appears on compilations you would want access to the songs directly..(searching through the compilation albums for the artists content would be a ball ache. Agree songs are lower priority.
