Samkook 18 Posted December 25, 2023 Posted December 25, 2023 (edited) I just updated to FreeBSD 14 since emby-server was gone when I upgraded my packages in 13.2 and now I'm getting a connection refused error when I try to open the web interface. The service does start but if I check the output of ps aux, the number in brackets seems to be incrementing, not sure if that's normal and I also remember always usually seeing 2 process there but only once I've seen 2: root /home/ai-san# psg emby emby 1662 0.0 0.0 12816 2384 - Ss 18:02 0:00.16 daemon: /usr/local/lib/emby-server/system/EmbyServer[5565] (daemon) emby 5565 0.0 0.0 14988 4216 - R 18:19 0:00.00 /usr/local/lib/emby-server/system/EmbyServer -os freebsd -ffdetect /usr/local/li root /home/ai-san# psg emby emby 1662 0.0 0.0 12816 2384 - Ss 18:02 0:00.17 daemon: /usr/local/lib/emby-server/system/EmbyServer[5830] (daemon) root /home/ai-san# psg emby emby 1662 0.0 0.0 12816 2384 - Ss 18:02 0:00.17 daemon: /usr/local/lib/emby-server/system/EmbyServer[5878] (daemon) root /home/ai-san# psg emby emby 1662 0.0 0.0 12816 2384 - Ss 18:02 0:00.17 daemon: /usr/local/lib/emby-server/system/EmbyServer[5890] (daemon) I do have the openssl 3.0.12_1,1 package installed unlike the other guy with the same issue. Edited December 25, 2023 by Samkook
Solution Duffyx 25 Posted December 25, 2023 Solution Posted December 25, 2023 Well you need openssl111 installed for dotnet to start correctly 1
Samkook 18 Posted December 25, 2023 Author Posted December 25, 2023 (edited) I was going to try that but after I installed it, I saw the package was deprecated so I figured that couldn't be the fix. Edit: It does fix it, but I assume that's just a temporary fix. Edited December 25, 2023 by Samkook
Luke 42237 Posted December 26, 2023 Posted December 26, 2023 3 hours ago, Samkook said: I was going to try that but after I installed it, I saw the package was deprecated so I figured that couldn't be the fix. Edit: It does fix it, but I assume that's just a temporary fix. That is the fix until we move to dotnet 8, which is built against openssl 3.0. But right now we use dotnet 6 and that requires openssl 1.1. 1
Samkook 18 Posted December 26, 2023 Author Posted December 26, 2023 Hopefully that is in the short term todo list because I've already had to reinstall openssl 1.1.1 3 times. Every time something has an openssl dependency, it installs 3.0 again and remove 1.1.1 so I have install 1.1.1 back after to replace 3.0. 1
SKull77 3 Posted December 29, 2023 Posted December 29, 2023 On 12/27/2023 at 12:15 AM, Samkook said: Hopefully that is in the short term todo list because I've already had to reinstall openssl 1.1.1 3 times. Every time something has an openssl dependency, it installs 3.0 again and remove 1.1.1 so I have install 1.1.1 back after to replace 3.0. You can always just pkg lock openssl for the time being. 1 1
Samkook 18 Posted January 15, 2024 Author Posted January 15, 2024 (edited) Not sure if I'm doing it wrong but locking the package does not seem to prevent it from being reinstalled or removed. That command would lock openssl 3, but it still gets installed and I also tried to lock openssl111-1.1.1w, just in case and that also doesn't prevent anything. I'm assuming the lock only works for manual installation and not when they're required by a package or something like that because I do have a confirmation they are locked. Edited January 15, 2024 by Samkook
redwards 2 Posted February 7, 2024 Posted February 7, 2024 Has version 4.9 beta been updated to the new openssl3?
Luke 42237 Posted February 7, 2024 Posted February 7, 2024 58 minutes ago, redwards said: Has version 4.9 beta been updated to the new openssl3? HI, no, not yet, sorry.
chaosmonger777 0 Posted February 11, 2024 Posted February 11, 2024 On 2/7/2024 at 4:34 AM, Luke said: HI, no, not yet, sorry. Hi Luke, I don't if this was mentioned before: if you move to dotnet 8, it landed in Ports two weeks ago (or so) - https://www.freshports.org/lang/dotnet/
Luke 42237 Posted February 12, 2024 Posted February 12, 2024 10 hours ago, chaosmonger777 said: Hi Luke, I don't if this was mentioned before: if you move to dotnet 8, it landed in Ports two weeks ago (or so) - https://www.freshports.org/lang/dotnet/ Hi, yes we will be in the near future. Thanks.
