finalreality 2 Posted December 24, 2023 Posted December 24, 2023 I have configured HW trascoding and it is working correctly, the FPS looks good, however tone mapping does not seem to be working. I have instaled emby diagnostics and enabled tone mapping for HW and SW transcoding with no limit for video resolution. Below is a screenshot from the video image, the colors are off: In attachment i have added the emby server and ffmpeg logs. Am I missing something? embyserver (1).txt ffmpeg-transcode-a5a8550f-68d0-4036-b1d2-2053030ce862_1.txt ffmpeg-transcode-74a3e3fe-fade-4e25-8521-5f924cf47ffc_1.txt
Solution samuelqwe 317 Posted December 24, 2023 Solution Posted December 24, 2023 I haven't looked at the logs, but looking at the image it seems that you have a Profile 5 Dolby Vision file. These files only contain a Dolby Vision track, which Emby cannot tone map. Emby only supports tone mapping HDR10 content AFAIK. Dolby Vision Profile 7 and most Profile 8 files would also work because they contain an HDR10 fallback layer for devices that do not support Dolby Vision. 1 1
finalreality 2 Posted December 27, 2023 Author Posted December 27, 2023 Thank you, yes that was correct, using a different file with HDR10 tone mapping woks correctly. 1 1
