Allina 0 Posted December 23, 2023 Posted December 23, 2023 Hello administrator, may I ask whether when emby client calls strm file to play: http://example.com/1.mp4 video, should I push the stream through emby server or play the straight chain directly without going through its own vps server If push the stream through own server, how can i set it to play the straight chain directly? If there is no way, has the subsequent version considered changing the playback form of calling strm to play the straight chain, which can greatly alleviate the bandwidth pressure of my vps server Thank you very much!
Abobader 3484 Posted December 23, 2023 Posted December 23, 2023 Hello Allina, ** This is an auto reply ** Please wait for someone from staff support or our members to reply to you. It's recommended to provide more info, as it explain in this thread: Thank you. Emby Team
Luke 42185 Posted December 23, 2023 Posted December 23, 2023 Quote If push the stream through own server, how can i set it to play the straight chain directly? Hi, it goes through your server. There are currently no options to control this.
Allina 0 Posted December 24, 2023 Author Posted December 24, 2023 14 hours ago, Luke said: Hi, it goes through your server. There are currently no options to control this. Then have you considered changing to direct link play, so that the playback speed will not be limited by their own server bandwidth, but also to save costs. From what I've heard, jellyfin just plays it straight
Luke 42185 Posted December 27, 2023 Posted December 27, 2023 The problem with going straight is that we can't verify the legality of the links in your strm files, and that puts us at risk of getting in trouble with the app stores because they' are able to see whatever domains the app connects with. That wouldn't be an issue for something like the web app, but it would be for apps in the stores such as android, iOS, Roku, etc.
