jbscout 1 Posted December 23, 2023 Posted December 23, 2023 Using a Synology 920+ with emby-server-synology_4.7.14.0_x86_64.spk Sorry to bother, but I would like an expert opinion. Why is hardware acceleration failing (see log)? >>>>>> Selected Codecs Decoder Automatic software decoder Encoder x264 Software Encoder Max Bitrate: 781 Mbit/s Color Formats: YUV420P, YUVJ420P, YUV422P, YUVJ422P, YUV444P, YUVJ444P, NV12, NV16, NV21, YUV420P10, YUV422P10, YUV444P10, NV20, GRAY8, GRAY10 - Bit Depths: 8, 10, 12, 14 Profiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2) Info Previous transcoding attempt failed. Falling back to software transcoding. What can I do to fix it (i.e., make it use hardware)? And, is it telling me that it is converting the 4k video to 1080p? Is that a setting somewhere I need to fix? And where is that setting? >>>>>> Video Processing Steps for [0:0]: H.265 (HEVC) Step HW-Context Format SW-Format Size Next HEVC >> VAAPI vaapi_vld yuv420p10 3840x2160 >> scale_vaapi scale_vaapi >> VAAPI vaapi_vld nv12 1920x1080 >> hwdownload hwdownload >> - nv12 nv12 1920x1080 >> format format >> - nv12 nv12 1920x1080 >> format format >> - yuv420p yuv420p 1920x1080 >> overlay overlay >> - yuv420p yuv420p 1920x1080 >> format format >> - nv12 nv12 1920x1080 >> hwupload hwupload >> VAAPI vaapi_vld nv12 1920x1080 >> Thanks ffmpeg-transcode-659f34ae-97b1-4c47-8ca3-f7b0a0017788_1.txt
Luke 42185 Posted December 23, 2023 Posted December 23, 2023 Hi there, please attach the complete corresponding emby server and hardware detection log files. Thanks.
jbscout 1 Posted December 23, 2023 Author Posted December 23, 2023 Here you go Thanks hardware_detection-63838928969.txt ffmpeg-transcode-6a7a9381-9355-4a00-a26d-4df8c51d9245_1.txt embyserver.txt
Luke 42185 Posted December 26, 2023 Posted December 26, 2023 hi @jbscoutare you able to try the 4.8 beta server and see how that compares? Thanks.
