Jonathan1683 29 Posted December 23, 2023 Posted December 23, 2023 Hello, I noticed sometimes my posters are really low quality, is there a way to scan my library for them automatically? Also can we set them to automatically download good quality versions? Thank you,
Luke 42185 Posted December 24, 2023 Posted December 24, 2023 Quote I noticed sometimes my posters are really low quality, is there a way to scan my library for them automatically? Hi, there is no way to do this although it's not a bad idea. Could be a useful filter. Quote Also can we set them to automatically download good quality versions? On backdrop images you can set a min resolution but not other image types. We do use the most popular images first based on user voting on MovieDb/Tvdb/Fanart, etc, and usually that results in one of the better ones being chosen. When votes are equal then we prioritize higher resolution as a secondary sort order.
TMCsw 256 Posted December 25, 2023 Posted December 25, 2023 Not really what your asking but, you can use File Explorer to help find them... Combine this with the Explorer search function... (I prefer Linux but the Win file explorer is rather slick).
