liberawa 7 Posted December 21, 2023 Posted December 21, 2023 Please tell me how to display the Live TV programs on the homepage of the Emby TV version in the default channel order instead of in title order, just like the Emby mobile version. Thanks!
ebr 16337 Posted December 21, 2023 Posted December 21, 2023 Hi. They display in the order you have your guide sorted.
Luke 42244 Posted December 22, 2023 Posted December 22, 2023 10 minutes ago, liberawa said: It's ok, thanks HI, what he's saying is, update your sorting in the guide and then the other places will match. Does that answer your question?
liberawa 7 Posted December 23, 2023 Author Posted December 23, 2023 The guide data source comes from the Internet. From the same guide data source, why by default the live TV programs on the emby homepage on computers and mobile phones are displayed in channel order, but on TV they are sorted by title. Manually adjusting the guide sorting on the TV can indeed change the order of programs display, but many users don't know it. I would like to ask if programs and guides can be sorted by channel by default in all clients.
liberawa 7 Posted December 23, 2023 Author Posted December 23, 2023 In fact, it is just to change the default order of the emby TV app's live TV programs and guides to the default channel order, so that they can be displayed uniformly without causing confusion.
ebr 16337 Posted December 23, 2023 Posted December 23, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks.
liberawa 7 Posted January 1, 2024 Author Posted January 1, 2024 Android phone app can't run on this tvbox (s905l3 cpu). The following are the emby homepages of the three devices: 1.android tvbox (s905l3 cpu) 2.nvidia shield tv 3.android phone
ebr 16337 Posted January 1, 2024 Posted January 1, 2024 At least two of those are logged in as different users so they will potentially have different orders - depending on how the guide sort order is set for each of them.
liberawa 7 Posted January 21, 2024 Author Posted January 21, 2024 The same user logged in above and the guide sort order never changed.
ebr 16337 Posted January 21, 2024 Posted January 21, 2024 Do the channels shown there in your second image show in the exact same order as they do when you bring up the guide?
