Jaster91 7 Posted November 1, 2014 Posted November 1, 2014 Hi there I've re-installed recently win 8.1 WMC and obviously MB3 Server, Classic, theater and the newly store app (BINGO!) Now when i play a DVD rip with MB3 Classic, it crashes after few seconds and if I try to reload the same movies it does'nt start at all In the attached file U can check the log The crash happens just at the end of the file, around 19:50 Can U give me some support please? Thank U in advance MBClassic-1112014b3bd2ecde3394772893ad61ea1560dac.log
ebr 16335 Posted November 1, 2014 Posted November 1, 2014 Can you specifically define "it crashes"? What, exactly, happens? In that log, it looks like you played something and then stopped it. There are no errors reported on our end. If you are getting an "invalid application" error, then we'll need the Windows Event log error.
Jaster91 7 Posted November 1, 2014 Author Posted November 1, 2014 Hallo simply the playback stops and no othrr DVD rip can be played, neither with mb classic nor in wmc but library is still accessible in both menus where I can find the Windows event log for that issue? Thanks for the help
Cheesegeezer 3106 Posted November 1, 2014 Posted November 1, 2014 (edited) Hallo simply the playback stops and no othrr DVD rip can be played, neither with mb classic nor in wmc but library is still accessible in both menus where I can find the Windows event log for that issue? Thanks for the help Follow link in my signature. But if you are not getting invalid application popup you wont need the event log. Try disabling the custom player in the mbc config inside mbc itself, think its under playback and see if that changes anything. Also what container is the rip in? Iso or videoTS folder? Do you have codecs installed other than the ones MBT forces you to install. Can you play non ripped media files? Are you using a remote to start the playback or clicking on the play button? Edited November 1, 2014 by Cheesegeezer
Solution Jaster91 7 Posted November 2, 2014 Author Solution Posted November 2, 2014 Problem Solved. I' ve found the solution on another forumUnticked "Allow application to take exclusive control of this device" checkbox in audio driver settings. here the complete link http://shark007.net/forum/Thread-VIDEO-TS-playback-problem maybe it helps other than me 2
Cheesegeezer 3106 Posted November 2, 2014 Posted November 2, 2014 Problem Solved.[/size] I' ve found the solution on another forum[/size]Unticked "Allow application to take exclusive control of this device" checkbox in audio driver settings.[/size] here the complete link[/size] http://shark007.net/forum/Thread-VIDEO-TS-playback-problem maybe it helps other than me Nice!! I was leaning towards codecs and a remote repeater issue, but glad you found a solution and for sharing!
