learch74 8 Posted December 18, 2023 Posted December 18, 2023 My guide is failing to update. The refresh starts for about 1 second and closes. I've attached the log file. embyserver.txt
learch74 8 Posted December 18, 2023 Author Posted December 18, 2023 Also, I went through log and then deleted the guide for all echostar and direct tv guides and now it will update. 2023-12-18 19:47:40.737 Info HttpClient: GET https://host2/v1.1/lineups/USA-DITV-DEFAULT/channels?enhancedCallSign=true 2023-12-18 19:47:41.030 Error LiveTvManager: Error refreshing channels for service What is the URL host2 ? that seems to be the problem. When that is working, I will restore my server so I can have guide for those channels as well.
axelsl 19 Posted December 19, 2023 Posted December 19, 2023 Same issue for me - this is quite a big issue since it disables the Channels setup screen altogether...
axelsl 19 Posted December 19, 2023 Posted December 19, 2023 FYI I had to remove the following Emby guides that were failing: USA-CA02268-DEFAULT USA-DITV-DEFAULT 2023-12-18 16:18:14.293 Error LiveTvManager: Error refreshing channels for service *** Error Report *** Version: 4.8.0.62 Command line: C:\Users\xxx\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\xxx\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows 10.0.22621 Framework: .NET 6.0.25 OS/Process: x64/x64 Runtime: C:/Users/xxx/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Data path: C:\Users\xxx\AppData\Roaming\Emby-Server\programdata Application path: C:\Users\xxx\AppData\Roaming\Emby-Server\system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: BadRequest at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at EmbyGuideData.Gracenote.GetChannels(ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetEpgChannelData(IListingsProvider provider, ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.QueryChannelsAsync(ChannelManagementQuery query, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetChannelsAsync(CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.RefreshEmbyChannelsInternal(IProgress`1 progress, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.RefreshChannels(IProgress`1 progress, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext() Other Emby guides I use do not have the same issue.
Luke 42185 Posted December 19, 2023 Posted December 19, 2023 It's possible that Gracenote changed their lineups, meaning you might have to remove the guide data source and then add back a new one that they created. Can you try that? Thanks.
axelsl 19 Posted December 19, 2023 Posted December 19, 2023 @LukeIndeed I added back a guide corresponding to DirectTV and it is now called USA-DITV-X in the logs and it works. Thanks! PS: It would be great that one failing guide does not disable the Channels set up screen
Luke 42185 Posted December 19, 2023 Posted December 19, 2023 5 minutes ago, axelsl said: @LukeIndeed I added back a guide corresponding to DirectTV and it is now called USA-DITV-X in the logs and it works. Thanks! PS: It would be great that one failing guide does not disable the Channels set up screen I agree and we'll relay this feedback to them. Thanks.
learch74 8 Posted December 19, 2023 Author Posted December 19, 2023 (edited) Is there any way to export the current channel mappings? IE Channel 5 uses Directv channel 202? I'll use my current guide mappings that don't work to know eastly what provider to get and what channel to pick on that provider. If not, can I at least see the channels so I can go into them manually and get the mappings? Edited December 20, 2023 by learch74 request more info.
Luke 42185 Posted December 20, 2023 Posted December 20, 2023 1 hour ago, learch74 said: Is there any way to export the current channel mappings? IE Channel 5 uses Directv channel 202? I'll use my current guide mappings that don't work to know eastly what provider to get and what channel to pick on that provider. If not, can I at least see the channels so I can go into them manually and get the mappings? Currently no, sorry. Apologies for the disruption. We're talking to Gracenote this to prevent this from happening. Thanks.
Chillout 111 Posted December 20, 2023 Posted December 20, 2023 You dont have to remove the guides, just update the lineup. So if it was your direct TV guide that is now blank in the lineup just re-select DITV in your list and your channels will re-map to the new guide. 1
learch74 8 Posted December 20, 2023 Author Posted December 20, 2023 (edited) 21 hours ago, Luke said: Currently no, sorry. Apologies for the disruption. We're talking to Gracenote this to prevent this from happening. Thanks. I actually found a simple fix. for anyone who has this problem. Shutdown the Emby server. Modify \Emby Server\Config\livetv.xml change the name of the quide services from <ListingsId>USA-ECHOST-DEFAULT</ListingsId> to <ListingsId>USA-ECHOST-X</ListingsId>. Save the file. Restart the server and the channel update will work. Edited December 20, 2023 by learch74 type-o
ebr 16307 Posted December 21, 2023 Posted December 21, 2023 16 hours ago, learch74 said: I actually found a simple fix. for anyone who has this problem. Shutdown the Emby server. Modify \Emby Server\Config\livetv.xml change the name of the quide services from <ListingsId>USA-ECHOST-DEFAULT</ListingsId> to <ListingsId>USA-ECHOST-X</ListingsId>. Save the file. Restart the server and the channel update will work. Wouldn't just using the Emby UI to change the lineup also work?
