tomadick 8 Posted December 17, 2023 Posted December 17, 2023 Hello I am writing to express my concerns regarding a recurring issue with incomplete recordings. Unfortunately, I frequently encounter this problem, where recordings stop prematurely. To illustrate, I initiated three recordings yesterday. While two were successfully completed, one was unfortunately incomplete. This situation is quite frustrating, especially when one looks forward to a recorded show, only to find it cut short. Thank you for addressing this matter. embyserver.zip 1
Luke 42241 Posted December 17, 2023 Posted December 17, 2023 HI, the recording in this log was set to run for 136 minutes and it appears that it did.
tomadick 8 Posted December 18, 2023 Author Posted December 18, 2023 Start of the program and recording at 15:15, end of the program at 17:55, end of the recording after 3 minutes and 24 seconds.
Luke 42241 Posted December 26, 2023 Posted December 26, 2023 HI, can you try refreshing the metadata on that video and see if it updates the duration? Thanks.
tomadick 8 Posted January 18, 2024 Author Posted January 18, 2024 First of all, when I go to Recordings under Live TV, there are no (!!!) recordings to be found. That's why I put Recordings directly under my media in order to be able to access the recordings at all. On 16.01.24 from 19:05 I recorded ""Galileo" accompanies three young people in New York, the city of dreams" - the program runs until 20:15 and 40 minutes were recorded, I also recorded the program https://www.tvinfo.de/fernsehprogramm/1833408316-darber-staunt-die-welt-typisch-mann-typisch-frau on 16.01.2024 at 20:25, which was recorded for 24 seconds.
tomadick 8 Posted January 18, 2024 Author Posted January 18, 2024 Small addendum: When I delete one of the many incomplete recordings, emby then jumps back to the start screen and not to the recordings... It would be helpful here if I could stay with the recordings.
Luke 42241 Posted January 18, 2024 Posted January 18, 2024 9 hours ago, tomadick said: First of all, when I go to Recordings under Live TV, there are no (!!!) recordings to be found. That's why I put Recordings directly under my media in order to be able to access the recordings at all. On 16.01.24 from 19:05 I recorded ""Galileo" accompanies three young people in New York, the city of dreams" - the program runs until 20:15 and 40 minutes were recorded, I also recorded the program https://www.tvinfo.de/fernsehprogramm/1833408316-darber-staunt-die-welt-typisch-mann-typisch-frau on 16.01.2024 at 20:25, which was recorded for 24 seconds. Do you see the recordings in the web app?
tomadick 8 Posted January 18, 2024 Author Posted January 18, 2024 Not under Live TV - but under recordings.
Luke 42241 Posted January 18, 2024 Posted January 18, 2024 Do you have recording folders configured in live tv setup?
