GuyJr 0 Posted December 16, 2023 Posted December 16, 2023 I cannot connect via any PC connected to the home network. I used to be able to. It works fine with my television and the cellulars. I've checked for the port fowarding (eventhough it's internal home network) and it all fine. Everytime I try to connect I get this error message. Sorry it's in French but basically it says impssible to join the server. It does not work if I try with the ip address in the internet address bar. I can confirm I can access my server (NAS) without any problem from the PC. I just can't connect to the Emby server. I put my cell on airplane mode to make sure it was only connected via wifi and it works. Please help it's really frustrating. Thanks, Guy
Luke 42237 Posted December 16, 2023 Posted December 16, 2023 HI, did you read the the top dialog and try either of the two suggestions that it provides?
GuyJr 0 Posted December 17, 2023 Author Posted December 17, 2023 As far as the first solution goes, I don't know how to do it and the link it brings us to is griberish for me. I'm not going to buy a domain name for an application that was working previously. It's a somple thing to connect to an application normallly. So simple my television does it. I just don't understand why it's so complicated. I simply want to connect a PC that is already on the same home network.
GrimReaper 4893 Posted December 17, 2023 Posted December 17, 2023 (edited) Have you confirmed that the actual address in the address bar states http://app.emby.media and not https://app.emby.media (no "s" in https and no padlock icon)? Edit: Alternatively, you don't need to use hosted Web app but use local one instead, just type http://IP:Port in your browser (in your example: http://192.168.2.35:8096). Edited December 17, 2023 by GrimReaper Append
