Vicpa 612 Posted December 21, 2014 Author Posted December 21, 2014 (edited) Hi, Thanks! It is a good idea to have support regardless of the firmware version. I guess Krusty can tell if the change supports the new firmware as well. Edit: Check out the new HD View for windows if you update firmware. It is nice, has some basic guide data, great picture and sound (ac3). Uses the dlna rui interface. Works great with HD Prime. Edited December 21, 2014 by Vicpa
techywarrior 689 Posted December 21, 2014 Posted December 21, 2014 Krusty, I'll leave my firmware version alone for now so we can test anything until you are satisfied that everything is working. At that point I'll probably update the firmware just in case there are additional fixes in it. That will leave us perhaps without a way to test this particular issue in the future but at least we could always fall back to "update the firmware".
