Hispanico957 23 Posted December 15, 2023 Posted December 15, 2023 (edited) I am encountering audio/video synchronization problems on 4K films many times on my 2nd gen Firestcik 4K MAX (2023), especially after a while (for simplicity after half of the movie) and only through the "Playback Correction" menu "I can fix the problem. Watching movies on my Emby server within my internal LAN also happens. How is it possible that Emby has this problem, considering that the exact same film seen with a normal player on FireStck does not present this problem? How can it be fixed permanently? Thank Hispa Edited December 15, 2023 by Hispanico957
Luke 42185 Posted December 16, 2023 Posted December 16, 2023 Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. 1
Hispanico957 23 Posted December 16, 2023 Author Posted December 16, 2023 8 hours ago, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Ok i try but the app for andorid is not design for FireTv. it's very minimal and doesn't have any settings options like emby for the FireTV Hispa
visproduction 328 Posted December 16, 2023 Posted December 16, 2023 Related? https://www.reddit.com/r/fireTV/comments/9yihhr/new_fire_stick_4k_has_terrible_audio_sync_delay/ https://www.amazon.com/gp/help/customer/display.html%3FnodeId%3DGRZKUFGWX49Z6SWC
Luke 42185 Posted December 16, 2023 Posted December 16, 2023 13 hours ago, Hispanico957 said: Ok i try but the app for andorid is not design for FireTv. it's very minimal and doesn't have any settings options like emby for the FireTV Hispa Hi, why do you think it's not designed for Fire TV?
Hispanico957 23 Posted December 17, 2023 Author Posted December 17, 2023 9 hours ago, Luke said: Hi, why do you think it's not designed for Fire TV? SOrry because on Store there are Emby for Android TV (for Firestick) and Emby for Android (for phones)... Good sunday Hispa
Luke 42185 Posted December 17, 2023 Posted December 17, 2023 10 hours ago, Hispanico957 said: SOrry because on Store there are Emby for Android TV (for Firestick) and Emby for Android (for phones)... Good sunday Hispa Is that the only reason why you think that? Because I can tell you that it is fully designed for TV devices.
Hispanico957 23 Posted December 18, 2023 Author Posted December 18, 2023 On 12/17/2023 at 8:06 PM, Luke said: È questo l'unico motivo per cui lo pensi? Perché posso dirti che è completamente progettato per i dispositivi TV. Ok thank and uderstand...but why then 2 versions ? So my question is for my FireStick 4K MAx which version is best suited? Hispa
Luke 42185 Posted December 18, 2023 Posted December 18, 2023 6 minutes ago, Hispanico957 said: Ok thank and uderstand...but why then 2 versions ? So my question is for my FireStick 4K MAx which version is best suited? Hispa It’s only two versions temporarily. We are working on getting the app into the store for TV devices. Thanks. 1
Hispanico957 23 Posted December 19, 2023 Author Posted December 19, 2023 PLS LUKE... i buy new NVIDIA SHIELD Android TV Pro (thisis an android Tv different form Firestick that i use now) and on this new device you suggest to install Emby Andorid or Emby for TV ?? Thank Hispa
Luke 42185 Posted December 19, 2023 Posted December 19, 2023 20 minutes ago, Hispanico957 said: PLS LUKE... i buy new NVIDIA SHIELD Android TV Pro (thisis an android Tv different form Firestick that i use now) and on this new device you suggest to install Emby Andorid or Emby for TV ?? Thank Hispa Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. 1
Hispanico957 23 Posted December 19, 2023 Author Posted December 19, 2023 (edited) 4 hours ago, Luke said: Hi. Can you try sideloading our standard android app on the same device and see how that compares? https://emby.media/emby-for-android.html Thanks. Ok sure i try but in specifications of NVIDIA SHIELD Android TV Pro i see that is "NVIDIA® Tegra® X1+ processor with a 256-core GPU"....so sry which version i must install ? Pheraps arm64 or arm7 ? At this page Emby for NVIDIA Shield - Emby which is ? Thank again and sry Hispa Edited December 19, 2023 by Hispanico957
Luke 42185 Posted December 26, 2023 Posted December 26, 2023 On 12/19/2023 at 5:33 PM, Hispanico957 said: Ok sure i try but in specifications of NVIDIA SHIELD Android TV Pro i see that is "NVIDIA® Tegra® X1+ processor with a 256-core GPU"....so sry which version i must install ? Pheraps arm64 or arm7 ? At this page Emby for NVIDIA Shield - Emby which is ? Thank again and sry Hispa @Hispanico957 Hi, for the Shield, please try the arm64 version. Thanks.
