DeVinesHome 0 Posted December 15, 2023 Posted December 15, 2023 Hallo zusammen, ich habe ein Problem mich über Emby Connect mit meinem Server zu verbinden. Gebe ich die benötigten Zugangsdaten ein sieht es zunächst so aus, als würde eine Verbindung aufgebaut werden. Dann komme ich jedoch immer zur Seite zurück, wo man auswählen kann, wie man sich einloggen möchte. Lege ich aber manuell eine Serververbindung über die externe-IP Adresse an, kann ich ohne weiteres auf meinen Server zugreifen. Die Portweiterleitung am Router und die Firewall am Server habe ich konfiguriert. Bei Emby Connect habe ich meinen Zugang richtig angelegt. Was kann ich noch tun?
GrimReaper 4895 Posted December 15, 2023 Posted December 15, 2023 Do you have SSL setup on your server? Your browser is likely force redirecting you to https://app.emby.media, try using http://app.emby.media (drop the "s" from "https"). Check that that address is actually shown in your address bar (http, not https and you have no lock icon). Have a read here also:
DeVinesHome 0 Posted December 15, 2023 Author Posted December 15, 2023 Hi, thank you for your advise. But this solution doesn't solved my problem. I tried also to login to the server by using the Emby App on iOS an there is the same problem.
GrimReaper 4895 Posted December 15, 2023 Posted December 15, 2023 Ok, let's start from the beginning: you have already linked your local user to an existing Connect account? If you go to http://app.emby.media (NOT https://app.emby.media unless you have SSL setup on your server) and enter same Connect credentials, what happens? Can you share a screenshot (including visible browser address bar)?
DeVinesHome 0 Posted December 15, 2023 Author Posted December 15, 2023 Yes I did and I will return back all the time to the page where I have too choose wich connection I prefer.
GrimReaper 4895 Posted December 15, 2023 Posted December 15, 2023 (edited) That second screen would indicate you don't have any server (/user) linked with that specific Connect account. What you can try is unlink Connect account in that local user settings on your server (blank out "Optional Connect e-mail" field>Save), and then re-enter e-mail address>Save, Verify account linking in received email and try again. Edited December 15, 2023 by GrimReaper
Luke 42239 Posted December 15, 2023 Posted December 15, 2023 @DeVinesHomeplease let us know if this helps. Thanks.
