elshagon 44 Posted October 19, 2013 Posted October 19, 2013 I had an MBC update this morning and when installing it just disappeared without fully installing. I tried downloading and installing from the website, same issue. I was able to finally install it and here was the problem: I don't use a MBC shortcut on my desktop, I only have it pinned to the taskbar along with the shortcut placed elsewhere. When I put a shortcut on my desktop and then try installing the update it then installs. Is this how it's supposed to be? You must keep the shortcut on the desktop or it won't upgrade? I like keeping my desktop free of all icons. I had the same issue on my other htpc as well.
ebr 16332 Posted October 19, 2013 Posted October 19, 2013 No, it shouldn't be that way. Can I please see the log from one of the failed installs. It will be in %appdata%\mediabrowser-InstallLogs
elshagon 44 Posted October 20, 2013 Author Posted October 20, 2013 I will grab the logs tomorrow, been gone all day.
elshagon 44 Posted October 20, 2013 Author Posted October 20, 2013 Just looked and I only see the one install log from the one which was successful. Is there supposed to be logs from the unsuccessful attempts?
ebr 16332 Posted October 20, 2013 Posted October 20, 2013 No, we only keep the last one. If you don't mind, make it fail again and post the logs. Thanks.
elshagon 44 Posted October 25, 2013 Author Posted October 25, 2013 Here's the log from my other HTPC which has the same type of setup and had the same problem updating: MediaBrowser.Classic.Installer.exe Information: 0 : Installing Media Browser Classic MediaBrowser.Classic.Installer.exe Information: 0 : Attempting to retrieve latest version of MBClassic MediaBrowser.Classic.Installer.exe Information: 0 : Found 1 versions. Will choose latest one of Dev class MediaBrowser.Classic.Installer.exe Information: 0 : Version is 3.0.83.0 MediaBrowser.Classic.Installer.exe Information: 0 : Downloading Media Browser Classic version 3.0.83.0 MediaBrowser.Classic.Installer.exe Information: 0 : Successfully downloaded version 3.0.83.0 MediaBrowser.Classic.Installer.exe Information: 0 : Archive is MSI installer C:\Users\Q\AppData\Local\Temp\MediaBrowser\MediaBrowserClassic.msi MediaBrowser.Classic.Installer.exe Information: 0 : Calling msi install MediaBrowser.Classic.Installer.exe Error: 0 : Error shutting down - InvalidOperationException - Cannot set Visibility to Visible or call Show, ShowDialog, Close, or WindowInteropHelper.EnsureHandle while a Window is closing. MediaBrowser.Classic.Installer.exe Information: 0 : Attempting to start program C:\Windows\ehome\ehshell.exe /nostartupanimation /entrypoint:{CE32C570-4BEC-4aeb-AD1D-CF47B91DE0B2}\{FC9ABCCC-36CB-47ac-8BAB-03E8EF5F6F22} MediaBrowser.Classic.Installer.exe Information: 0 : Installation complete
ebr 16332 Posted October 25, 2013 Posted October 25, 2013 And it didn't work? There should also be a msiinstall.log in there...
elshagon 44 Posted October 25, 2013 Author Posted October 25, 2013 It didn't install and it was the only log in the folder. As with the other pc the update would only install once I placed an MBC shortcut on my desktop. After doing that the update installed without any problems. I use no shortcuts to apps on my desktop screens for my htpc's but rather pin them to the taskbar so I can open the app with my remote control.
ebr 16332 Posted October 25, 2013 Posted October 25, 2013 Is there anything in the Windows event log?
